65 wiper
Old May 26, 2020 | 07:08 PM
664x4drvr's Avatar
664x4drvr
65 wiper
My 65 wiper has the excessive travel on the Driver side as is common on some trucks. Some guys are suggesting to replace the whole system with new parts , not used. Does anyone know which part goes bad since its usually the driver side that hangs up ?
Old May 26, 2020 | 07:47 PM
resonateur's Avatar
resonateur
I believe that there is an adjustment in the wiper motor for travel???...however, I could be wrong. The other option is simply to remove and reinstall the driver's side wiper arm to the position that's correct. In either case, I doubt that replacing all with new parts is necessary....I think you can simply fix what you have.
Old May 26, 2020 | 07:58 PM
Becky_is_a_66's Avatar
Becky_is_a_66
There is a bushing at each end of the link between the wiper motor and the wiper pivot that passes through the cowl. The bushing has a rubber like center; maybe check those for slop. Also check that the nut on the outside of the cowl that secures the wiper pivot is not loose. There is a park adjustment that can be made by removing the cover of the wiper motor, but that is unlikely to fix excessive wiper travel on one side.
oldmerc
17
Apr 13, 2012 06:33 PM
Truxx1956
Jun 15, 2011 08:03 AM
Redmanbob
Oct 13, 2007 02:13 AM
66ranger
May 26, 2002 06:22 AM
