Downside to Disabling Battery Management System?
Old May 25, 2020 | 12:06 PM
CrossCut's Avatar
CrossCut
Are there any downside aspects to disabling the Battery Management System? My Ford Pinto didn't have one. So why does my 2014 FX4 Ecoboost need one?
Cheers
Old May 25, 2020 | 12:53 PM
steve(ill)'s Avatar
steve(ill)
how are you going to disable it ??......... and WHY ? what is it hurting ?
Old May 25, 2020 | 09:34 PM
CuNmUdF250's Avatar
CuNmUdF250
From my understanding it doesn’t affect anything, positive would be the battery is always being charged while the truck is running. I’ve been meaning to disable mine as I have fairly large amp and subwoofer and I would think it might help feed the monsters better
Old May 25, 2020 | 10:34 PM
Siberexpress's Avatar
Siberexpress
Cheers
You will getabout .00001 Less mile to the Gallon of Gas.
BTW the 6.2 did not come with it, seems like they didn't need it on it because they knew better.
Old May 26, 2020 | 09:56 AM
CrossCut's Avatar
CrossCut
Q: Why defeat BMS?
A: So I can listen to audio for more than a handful of minutes while I'm working in the garage. (I'm assuming it's the BMS that cuts off the audio.)
If I drop the voltage too low and damage the battery, that should be my fault. But let me make that decision.
Gothere
Apr 21, 2021 01:50 AM
JoePa2
2009 - 2014 F150
Nov 4, 2020 08:48 AM
ArmamentDawg
2015 - 2020 F150
46
Jan 11, 2019 07:16 AM
dancraig
Jan 23, 2012 10:00 PM
emd160
6.7L Power Stroke Diesel
Nov 20, 2011 04:06 PM
