2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Brake light
Old May 25, 2020 | 09:41 AM
spec5's Avatar
spec5
Brake light
I have a 2008 Navigator that the brake light stays on. I have replaced the reservoir and sensor along with the emergency brake light switch but the light still stays on. Anybody got any suggestions. Thank you for your reply.
Old May 25, 2020 | 12:32 PM
projectSHO89's Avatar
projectSHO89
Are you talking about the BRAKE light in the cluster? There's a common failure in the driver circuit in the cluster itself that causes the issue. Forum sponsor Circuit Board Medics can repair it.
Old May 25, 2020 | 01:52 PM
spec5's Avatar
spec5
Brake light
That would be the one. Where can I find the Circuit board medics forum?
Old May 25, 2020 | 02:36 PM
projectSHO89
Up there near the top of the page where it says "Vendor Directory". They should be listed there. Or, SEARCH for their screen name (no spaces).
Old May 25, 2020 | 03:49 PM
spec5's Avatar
spec5
Brake light
Thanks, I'll give it a try
Old May 26, 2020 | 10:48 AM
alloro's Avatar
alloro
The brake light or the ABS light?
Old May 26, 2020 | 11:33 AM
spec5's Avatar
spec5
Brake light
It is the brake light.
Old May 27, 2020 | 08:44 AM
CircuitBoardMedics's Avatar
CircuitBoardMedics
spec5,
We do repair several instrument clusters for that particular issue. In this case, this is not a cluster we usually see this particular failure with. After looking at the wiring diagrams, it seems that both the parking brake switch and brake fluid level switch both are sending signals directly to the Smart Junction Box then the SJB is communicating with the cluster over CAN lines (on the other clusters we repair these are both direct inputs to the cluster), so without more troubleshooting it would be hard for me to determine if it is likely the cluster or not. The easiest thing to do would be to hook up a scan tool and see if that information is being communicated properly. If it is being communicated properly, then it is likely an issue with the cluster. Feel free to message us if you have any questions we can help with.
Truck Guy99
Oct 18, 2015 02:51 PM
broncobillyII86
Bronco II
Mar 10, 2006 07:01 PM
flagator
Feb 19, 2005 08:56 AM
