Radiator Help
Old May 27, 2020 | 07:32 PM
72rtchallenger's Avatar
72rtchallenger
https://www.radiator.com/ sells good quality
Old May 27, 2020 | 09:27 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Kwe, I apologize. I assumed you were talking to me directly. But I sure didn't mean to imply you're an idiot. Thanks for smacking me into line!
Old May 28, 2020 | 10:27 AM
kwe45919's Avatar
kwe45919
Its all good. I thought I missed something and read the post 5 more times looking for a pic or a link. I even checked my emails just to make sure I didn't miss anything before I posted.
Old Jul 16, 2020 | 05:10 PM
orangeford's Avatar
orangeford
Originally Posted by ford390gashog
Were do the cracks develop? My oldest Champion radiator is almost 10 years old and no issues. The biggest issue I see with mounting aluminum radiators in these trucks is people don't use isolators. The radiators should have the ability to flex independently of the core support. I use single hole 3/8" isolators between the core support and radiator flange.
Do you have a picture of this isolator you speak of or a pic of the radiator mounts?
I just found a decent seep from my $800 griffin I installed in my 79 5 years ago. Kinda pissed. Been shopping for new but US radiator wants close to $1000 for the original style 4 row. Considering the tall champion now that they make one but want to make sure it is isolated. My concern is spacing the radiator closer to the engine.
Old Jul 16, 2020 | 06:03 PM
matthewq4b's Avatar
matthewq4b
If you still have a rad shop in your area have them repair it. No point spending the money on a new rad when yours could be repaired...
Old Jul 17, 2020 | 11:25 AM
Lrrr-RulerOfOmicronP's Avatar
Is there a reason you cannot run an aftermarket radiator from rockAuto? They are plastic tank but you can get them in single or double core (aluminum). I think the cores are 1-1/4 wide if I remember correctly. I have ran one without a problem.
Old Jul 17, 2020 | 01:18 PM
bluovl's Avatar
bluovl
Ok, here's what's mounted in my 78 Bronco. This is the Champion Big core for trucks equipped with Super Cooling option from the Factory. It's a direct bolt in. It's 3 rows. It replaced the original which was 4 rows. However it's 3 rows are larger than original the rad. I don't have any isolators.
Note the mounting brackets, there are 2 different mountings. Which do you have?
krustiy lusti
18
Apr 9, 2017 07:22 PM
rpenterics
May 14, 2006 10:27 PM
maticuno
1997 - 2003 F150
Dec 11, 2005 07:07 PM
mark460
Jun 8, 2005 09:17 PM
