Post us some pic's of the connectors so we are not guessing as to what you actually need.
No one makes a true green module they are standard DSII Bule modules that have been rewired.
Yup not correct. That orientation on the power plug is the Green Module. The Black module has the location tabs clocked 90° from yours on the 3 pin plug.
Also the wiring colours on the 3 pin plug are not correct for the Black module. The Black module uses the following colour wires in the 3 pin plug Blue (Coil Power Run) Black (System Ground) Green (Coil Negative)
That is a Green module. The 3 pin plug on the Green module are Blue (Coil Power Run) Red (Bat Power Run) White (Bat Power Start)
No replacement Green or Black module will be a true Green or Black module they are rewired DS II (blue) modules.
Your truck uses the Green Module.
Now the question is how do you truck get a Green module with Black strain relief. Now, some of this is conjecture as your factory module predates my time with Ford, but all the Factory replacements when I was there were all colour coded properly.
I suspect that in 75 when SSI's wiring configuration was reconfigured to put all the power leads in the same plug Ford never bothered to change the colour of the strain relief and just continued to use black.
I suspect that colour coding was first done when DS II was introduced in 76 as it would make identification much easier. In 3 years they used 3 different modules and it would be a pain for the average parts guy or tech if you had to check the part numbers in the book to tell them apart. Colour coding the strain reliefs makes it a quick glance to identify them.
How's about a close-up pic of the strain-relief? Maybe the black is really a discolored green? Or not, but it would still be good to see next time you're under the hood with your camera.
And if for some reason that does not fix the issue, verify voltages at the wires and their condition. A low voltage reading on the Yellow sensing wire might be telling the alternator that it's not charging the battery.
I think that's the only wire that matters in a situation like this, since the Orange field wire not having a good connection would probably give the opposite problem.
You should see full battery voltage on the Yellow wire where it connects to the regulator. Anything less is not good. I'm sure there is some leeway, but really with that wire being spliced to the Black wire from the starter relay and the battery being right there, you should not see a voltage drop.
It's way more likely to be the regulator than the wire. But I thought I'd throw that out there just in case.
Thanks. Looks like a black strain relief to me too. But along the lines of what Matthew was saying, along with the fact that yours has the green orientation, the "D5AE" pretty much tells the tale as to what it was expected to fit. A '75 dated vehicle.
Looks in pretty good shape if it's an older unit. If it's original then it's in great shape!
Thanks for the additional pics. Now I'll have to go back and look for my pics of an NOS green module to see if I was smart enough to get a shot of the connectors.
But probably not...
But probably not...
Paul
You can not trust the engineering numbers on ignition modules as they were changed multiple times almost every year until the mid 80's as internal components were changed and improvements made. Even the current Motorcraft unit carries a 2001 date part number, a decade later than their last auto use, even after they quit being used they were being updated and the engineering number changed.
