Actually I plan on putting a cat on it. I really like to keep my truck as stock as possible and for everything to work. Just a **** about it.
makes sense. Kinda still on the fence with mine. Sometimes think delete A.I.S., sometimes think keep it. Decisions. Decisions. Decisions. Thanks sandymane.
My air pump is not on the idler pulley belt. If you are leaving the cat on the Banks you should run the air pump. If not the short belt is the way to go. Just take off the air pump pulley and install the new belt. Air pump is dead. My shorter belt is 53". Sandy
I just realized my mistake sandymane. You are correct. My air pump is NOT on the idler pulley belt. It is air pump/alternator/crankshaft, I believe. Right now front of motor is off for a refresh.
So back to square one. Either finding a bypass pulley. Or correct belt size.
Thanks for the help
