You asked the exact same question 2 months ago. Are you expecting a different results?
LOL, sorry, I did not realize that you are monitoring me. Wow,..........but any way, yes....there is a slight difference in results, it confirms the majority here uses Opti-lube brand!
it does have lubricity in it. I use it mostly because my equipment has no emissions problems with the it’s sad to say but my 2020 F350’s is cheap compared to a 80k motor in one of my tractors. I have no injector problems or pump I have less regenerations in my equipment. I have tractors burning 280gal a day of fuel some even more.
i have been using carbon treat for over 6 years now with motors with over 8k hrs with no injectors problems or pump. I’m over hrs on dpf filters that should of needed replacement. I have one tractor that I drive only that has never needed a manual reburn from what I’m told it’s unheard of with 1900hrs on it.
Any idea how much lubricity? Curious what a wear scar test shows with ULSD and carbon treat. My guess is your tractors have injection pumps that aren't prone to failure like the CP4?
Thats sad people have nothing else to do but monitor what everybody post on here and pop off smart *** comments.
