Fuel pump lubricant
Old May 23, 2020 | 07:59 AM
jimzpsd's Avatar
jimzpsd
Fuel pump lubricant
Survey time, just want to know what's being used other than the Ford brand ( which I've been using). Thanks
Old May 23, 2020 | 08:19 AM
cpobst's Avatar
cpobst
I use Hotshots Secret EDT.
Old May 23, 2020 | 08:29 AM
Lamoon78's Avatar
Lamoon78
I use Archoil
Old May 23, 2020 | 08:31 AM
cpobst's Avatar
cpobst
Project Farm did a great video comparing the different additives. I couldn't find it to post but I remember the Howes had less lubricity than straight diesel.
Old May 23, 2020 | 09:00 AM
67L48's Avatar
67L48
There are many, many threads here the discuss additives and lubricity. Opti-Lube is among the highest rated, particularly for lubricity. I use XPD and will be switching to XL soon. I don't care about all the other hyped up supposed benefits to an additive. I only care about lubricity.
Old May 23, 2020 | 09:06 AM
jollyrogr's Avatar
jollyrogr
Optilube XL here
Old May 23, 2020 | 09:58 AM
SDER1's Avatar
SDER1
I use Stanadyne Performance (Blue label) and Lubricity (Purple label) - combine my own mix for a long-bed (48 gal), since owning Aug 19. Per Stanadyne's site - formulas can be mixed, peace of mind and available at TSC.
Old May 23, 2020 | 10:12 AM
67L48's Avatar
67L48
Standadyne is better than nothing, but they didn't do much in the old Spicer study. I definitely wouldn't cut the Lubricity formula with the Performance blend. You want everything that the former can give you, as the latter does almost nothing for lubricity. I'd use Stanadyne in a pinch. But, for something that gave me a legitimate lubricity improvement, I'd look elsewhere.
Old May 23, 2020 | 10:29 AM
Keith Schumaker's Avatar
Keith Schumaker
another +1 for Optilube XL I have run it in this ford since day one.
Old May 23, 2020 | 01:04 PM
deerezilla's Avatar
deerezilla
We use Schaffer’s carbon treat for all our emissions equipment including my 2020 F350.
Old May 23, 2020 | 01:33 PM
jollyrogr's Avatar
jollyrogr
I’m a big Schaeffer’s fan and would like to use carbon treat but I haven’t found any data on the lubricity benefit of it.
Old May 23, 2020 | 03:22 PM
SARDiverDan's Avatar
SARDiverDan
In the garage, I have Power Service, Standadyne, and Opti-Lube XPD. I have used PS in the 02 for as long as I can remember. Never had an issue but I think these newer trucks are more prone to issues than the older models. For the 19, I am going to stick with XPD so I don't need to worry about changing the additive depending on the weather. Our Diesel Cetane rating is CA is higher than average so the additional bonus of the XPD is not really needed and while the XL formula appears to perform better in lubricity, I would rather have the higher water demulsifier in addition to lubricity. The anti-gel is a bonus so I don’t need to switch it over when I decide to drive up to Wyoming in the winter.
Old May 23, 2020 | 03:43 PM
BillyE's Avatar
BillyE
The only test I’ve ever seen is the spicer study from over ten years ago. It was good, but only tested a free brands. I have personally used the different Redline products, Optilube Summer, and Power Service silver bottle. I wish there was a more recent and comprehensive test.
Old May 23, 2020 | 06:32 PM
deerezilla's Avatar
deerezilla
it does have lubricity in it. I use it mostly because my equipment has no emissions problems with the it’s sad to say but my 2020 F350’s is cheap compared to a 80k motor in one of my tractors. I have no injector problems or pump I have less regenerations in my equipment. I have tractors burning 280gal a day of fuel some even more.
i have been using carbon treat for over 6 years now with motors with over 8k hrs with no injectors problems or pump. I’m over hrs on dpf filters that should of needed replacement. I have one tractor that I drive only that has never needed a manual reburn from what I’m told it’s unheard of with 1900hrs on it.
Old May 23, 2020 | 07:25 PM
hogryder007's Avatar
hogryder007
You asked the exact same question 2 months ago. Are you expecting a different results?
