2020 steering wheel
Old May 21, 2020 | 06:23 PM
Fmc128's Avatar
Fmc128
2020 steering wheel
Does anyone know are the F150 and 250 steering wheels the same. Aside from options, I have an xlt f250 and just got a deal on a leather wrapped wheel however it's out of a 150. Everything matches perfect as far as controls.
Old May 21, 2020 | 06:40 PM
BlackOps450's Avatar
BlackOps450
From what I have read on subject is that the airbag connection are not comparable. Other ran into this issue trying to swap for a raptor steering wheel.
Old May 21, 2020 | 06:44 PM
Fmc128's Avatar
Fmc128
Ok thanks, tried matching part numbers but they were different and I was assuming it was because of the trim in the middle plus the fact that an xlt doesn't get a leather wrapped one.
Old May 21, 2020 | 06:48 PM
BlackOps450
The search function isn't that great, but if you look for raptor steering wheel swap. It will explain and they might have figured out a fix. I stopped paying attention to that tread after a little. Hopefully you haven't committed to the deal yet.
Old May 21, 2020 | 07:04 PM
Fmc128's Avatar
Fmc128
No not yet. It would have been on the "last" thing to do as far as mods.
Old May 21, 2020 | 07:20 PM
ForCal's Avatar
ForCal
Don't you just reuse the airbag from your truck??
The swaps Ive seen use the donor steering wheel but not the donor airbag. No airbag connection issues.
Old May 21, 2020 | 07:44 PM
Fmc128's Avatar
Fmc128
That's what I saw also, however the videos I saw were 250 to 250
Old May 21, 2020 | 07:53 PM
ForCal's Avatar
ForCal
Same with the Raptor swaps. I have seen where the audio controls had to swap, not because of the connectors but because the icons dont match. Something like that.
Old May 21, 2020 | 10:22 PM
BlackOps450
https://www.ford-trucks.com/forums/s...1533217&page=4
Here you go I did not read up on it. Hope this helps
Old May 21, 2020 | 10:25 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I swapped a Raptor wheel into my truck. You just gotta use the SD's airbag.
Old May 22, 2020 | 03:42 AM
Fmc128's Avatar
Fmc128
The one I can get is out of a lariat not a raptor. Looks like from that thread I may pass and keep an eye out for a super duty specific wheel. I just want it for the feel.
Old May 22, 2020 | 04:43 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Don't quote me on this, but I believe any F150 wheel will have the same 'frame' in the guts where the airbag and switches mount. Any F150 wheel should accept the SD airbag and bolt into your SD.
I mentioned my Raptor wheel, because it is a F150 wheel.
Old May 22, 2020 | 09:22 AM
ForCal's Avatar
ForCal
Im not going to read 29 pages of a steering wheel swap thread, what page/post specifically gives you the idea that a Lariat F150 steering wheel wont be a direct swap?
I have found other posts saying an F150 Limited steering wheel was a direct swap to an F250. How is the Lariat so different than the others.
Old May 22, 2020 | 09:27 AM
PhilPalmiero's Avatar
PhilPalmiero
Why would you want to swap steering wheels?
Old May 22, 2020 | 09:30 AM
ForCal's Avatar
ForCal
He has an XLT, the Lariat and up have more of a leather wrapped like appearance, rather than just plastic. Common upgrade.
