FE newbie and need help
Old May 20, 2020 | 12:38 AM
Boggs83's Avatar
Boggs83
So I have a 410 out of a 66 Parklane and I'm trying to figure out what transmission can be bolted to it. It currently has a Merc-o-matic which is in desperate need of replacement. Now I've been told a c6 will bolt right up with no concern. I've also been told if I bolt a c6 up to it I'll have to change the flywheel, starter etc. So what can and cannot bolt up to it and what needs to be done when changed? Thank you
Old May 20, 2020 | 02:01 PM
85e150's Avatar
85e150
Welcome to FTE!
Read post 16 here. You may already have a C6. All automatics of that era were Ford-o-matic, Merc-o-matic or Cruise-o-matic. The MX, FMX, and C6 were all called the same thing. Your flexplate is unique to the 410/428 and should work for any C6 that has the FE pattern.
https://www.ford-trucks.com/forums/1...k-options.html
drexer13
Apr 5, 2012 12:32 PM
swampshaker99
Oct 14, 2011 10:33 AM
truckerboy
Apr 13, 2010 05:07 PM
ScottJM
Nov 16, 2003 07:18 PM
73-360-f100
Apr 15, 2003 06:44 PM
