I don't know how you were using the belt or even what type of belt it was, fan belt or pants belt?
I have used rope in the past. Run it around the tire cross it at the top run a long bar over the crossed part and cross it again.
Kind of making a tourniquet with the rope & bar, turn the bar to tighten the rope and pop the beads out.
Make sure the beads are well lubed up.
Dave ----
I've used the ratchet strap multiple times on different sized tires. Sometimes its a balancing act to find the right tension to get the bead to hold, but not too much air where you can't get the strap to loosen up.
