Sponsored by: Kumho
Storing tires
Old Apr 11, 2004 | 12:07 PM
albertafarmer's Avatar
albertafarmer
Question Storing tires
I just aquired 4 950R16.5 tires mounted on 8 hole Ford wheels. I want to use them on a project that is still in the planning stages. I will have to store these tires till then, probably 2 or more years. My question is should I store them with air in or deflated.
Old Apr 11, 2004 | 04:15 PM
threefiftyone's Avatar
threefiftyone
Can you lay them flat? It's not good idea to store them with air in the tires because flat-spotting can occur over time. After time passes and you mount them, they may ride harsh due to internal belt separation, and you'll have a permanent flat spot on the tire. This doesn't always happen though.
Old Apr 11, 2004 | 08:18 PM
albertafarmer
Thanks for the reply. They are laying flat in an unheated shed out of direct sunlight. How long will tires last in storage? I know I have used tires that have sat around outside for years and got some use out of them. I have farm machinery with tires on that are twenty or more years old, and are still going strong.
Old Apr 12, 2004 | 02:25 AM
threefiftyone
I don't know how they will last in storage, and I know tractor tires are different. It might have something to do with the harder rubber compound, and the fact that some tractor tires have anti-freeze in them.
Old Apr 13, 2004 | 12:37 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Sounds like the way you're storing them, they will be just fine.
Old Apr 13, 2004 | 08:55 PM
TeulonF250's Avatar
TeulonF250
grease them up with armour all to keep them from drying out.i do it to my quad and bike every winter and don't have any problems with splitting rubber.
HRTKD
All Things Towing
Mar 25, 2017 01:21 PM
gotroxs
Dec 13, 2016 01:37 PM
hmilycar
General Automotive Discussion
Jun 19, 2015 11:07 AM
qman
Dec 8, 2014 11:56 AM
scroller bill
1978 - 1996 Big Bronco
Oct 21, 2006 10:29 AM
