Putting a all new exhaust on the 80 I-6 and was going to just delete the cat if its not required or needed to be on there considering the year. Thoughts or experience doing this? Thanks
It is required by federal law, all 50 states. But some states do not have inspections, so if it's taken off, there is no one to give you any grief. It's one of the few things they do check for in Va inspections. You will have to fabricate something if you want to get rid of it. Most exhaust shops in my state will not take it off. And if your truck is all original with all the original emissions on it, taking it off will affect the EGR operation. You may get some pinging problems from it if it's all stock and you take it off. Been there, done that.
Franklin is right on what he posted.
Now my 81 with 1 300 six we don't have inspections and all the emission stuff has been removed so when I went with EFI exh. manifolds the new Y pipe comes with the cat.
I was also hooking the Y pipe to a almost new long bed system on my short bed truck so I left the cat off and used a short pipe to join the 2 pipes together.
Now I did have pinging but I never drove the truck when I first got it, took it all apart for cab off frame rebuild, so I don't know if it was there before I did this or not.
I think it was as nothing was hooked up under the hood as it was used on a farm.
I have not checked where my timing is at to start with but have adjusted the vacuum advance can on the dist. and that helped a lot.
The other thing I found to help is to run mid grade or better yet high test gas over regular gas.
Dave ----
Thank you gents. I'll just replace it then. All the smog stuff is still in place and I have no plans to remove it. I'm not 100 % but I don't think Texas does smog on a 40 year old truck but I don't want to cause any issues where I have none. I;m replacing the entire exhaust from the manifold back cause it's in terrible shape.I was just going to remove the entire run and drop it off at the shop and have them build it like for like and bring home and reinstall. Thank you!!
25+ years old is safety only. it has to pass a visual test but 99% of the inspectors out there will never bother to fail a safety truck on missing emission components. most realize that due to their age the components are not being made anymore to be replaced.
It depends on where you live. Some places are very strict, some don't care at all. We are about in the middle in Va. They are hot on catalytic converters and smog pumps here.
Yep, I cant say about other places but I know here in Texas, they dont care much when it comes to safety inspections. I used to do state inspections and I quickly learned I was the only one trying to go by the book and quickly learned to save time by over looking emission components on safety only inspections.
Here in NC my truck did not even need to do a safety before I got my plate.
In CT if from out of state or over 10 years old it had to get a safety before getting a plate.
Now if it must have a cat but don't want the "guts" cut open the top and gut it and weld it back up keeping the weld at the top.
I have seen them check with a mirror if you have a cat and if its been cut open on the bottom never at the top as they would need to get on the ground and mirror on the top of the cat.
In addition to what the others have already said Castaway, you really don't "need" to replace it just because you're doing a new exhaust. If it's still working and free-flowing enough, there's nothing that says you can't just put the new exhaust on around it. Most of your changes will be made after the cat anyway, so it might just make the addition easier and much less expensive.
That's what I would do in fact. I've replaced cats when needed, and even added them when I did not have one in a couple of instances, but if one is still working fine I'd just build the new exhaust around it.
Now, if you're going for max performance, a freeer flowing cat from someone like Magnaflow could be just the ticket. Otherwise the stock one will still allow some performance gains by a mild exhaust upgrade.
