T-19 Transmission codes
Old May 19, 2020 | 02:06 PM
Rovernut's Avatar
Rovernut
Apparently there are identifiers on T-19 transmissions. Something like these
WARNER - 1309-000-045
FORD - E3TA-7003-LC
I don't see them on mine, but it's pretty grungy.
Anyone know where they are located, or have a T-19 sitting around they could look at?
Thanks
Old May 20, 2020 | 05:59 AM
Rovernut's Avatar
Rovernut
Apparently the tag is on the left side at the rear of the case according to drivetrain.com
Old May 20, 2020 | 06:01 AM
Ken Blythen's Avatar
Ken Blythen
FORD - E3TA-7003-LC
Thanks
The Borg Warner number (1309......) is on the LH side of the case, above the PTO cover & is easy to see in good light. I can't remember if there was also a 1309 number cast into the lid.
The Ford number is only on the ID tag (at least on my trans), which originally was bolted on by one of the PTO cover bolts.
Rebuild time?
Old May 21, 2020 | 05:29 AM
Rovernut's Avatar
Rovernut
Thanks.
Rebuild time?
No, trying to determine which Chelsea PTO I need.
From what I can tell '85 F-250's came with one of these ratio's.
5.11,3.03,1.79,1.00
6.32,3.09,1.68,1.00
Supposedly the 4WD F-250 with 460 came with the 6.32 first, but I'm hoping to confirm.
Old May 21, 2020 | 06:48 AM
Ken Blythen
Thanks.
5.11,3.03,1.79,1.00
6.32,3.09,1.68,1.00
That does line up with the Novak info here......https://www.novak-adapt.com/knowledg...anual/t18-t19/...........but maybe that's also where you got it from.
magnumak1
May 4, 2014 06:10 PM
BoydGilley
2004 - 2008 F150
Jan 18, 2014 08:20 PM
tva13181
Aug 8, 2011 11:50 AM
choppersinc
1983 - 2012 Ranger & B-Series
Mar 1, 2005 08:29 PM
