300 i6 with C6 trans
Old May 18, 2020 | 07:17 PM
Bvanco93's Avatar
Bvanco93
I picked up a 95 F150 4x4 with a 300i6 and the guy before me had issues with the E4OD that was in it, so he threw a C6 in the truck. I don’t know much about the install or what he did. But it runs and drives. He rigged a piece of threaded rod through the floorboard and that is the current shifter. I have the stick E4OD shifter cable( I believe), came with the truck. I’m going crazy searching the internet trying to find out if this shift cable will work. What kind of mounting brackets I’ll need and so on. It also does not have a kickdown cable and I’ll need to find out which to buy in that instance also. Any help would be greatly appreciated
Old May 19, 2020 | 10:41 PM
Fomoko1's Avatar
Fomoko1
Welcome aboard! Hopefully someone with an answer will reply.
Old May 20, 2020 | 01:53 PM
tjc transport's Avatar
tjc transport
i ain't rite
see if you can find a shifter diagram for the 95 F150 4X4 with C6 trans. the C6 was an optional trans through 96. so there were probably a few made
Old May 20, 2020 | 07:24 PM
whisler's Avatar
whisler
Since I converted from 5 speed to C-6, I used a Hurst Pro-matic 2 floor shifter. Since it is a ratchet shifter I don't need no stinking kickdown rod or cable. Just a thought.
graveyardmedic
Dec 21, 2019 03:23 PM
finitetime
Jan 22, 2015 08:44 PM
custom1106
Mar 30, 2014 02:33 AM
6T6Shorty
Feb 28, 2007 01:30 AM
Katt
16
Nov 9, 1999 10:40 PM
