Crazy engine oil dipstick design
Old May 18, 2020 | 09:34 AM
AK2NC's Avatar
AK2NC
On my 2019 6.2L. Never seen such a crazy shaped dipstick. Felt I was going to break it trying to get it inserted. Is there a particular way to insert it or just shove it in?
Old May 18, 2020 | 09:51 AM
acadianbob's Avatar
acadianbob
It often works well to rotate the dipstick as you insert it. Don't force it but let it turn.
Old May 18, 2020 | 10:23 AM
h20camper's Avatar
h20camper
Worst dipstick I've ever seen. Pain in the a** to put back in. But as Bob mentions, it does help to let it rotate while inserting.
Old May 18, 2020 | 01:13 PM
Haggis 6.2's Avatar
Haggis 6.2
I've found that by pinching the stick about 2 inches from the tube I can shuffle it in quickly w/o binding.
Old May 18, 2020 | 03:18 PM
PentaPop's Avatar
PentaPop
Easy there, this is a family forum!
There’s lots of things I miss about my 04 6.0. The dipstick is one of them. The no mess oil filter mounted on top of the engine is another. The dipstick on this 6.2 definitely has a mind if it’s own. I just let it find it’s own way with using too much force. It seems to be happier that way.
Old May 18, 2020 | 03:38 PM
crewzer's Avatar
crewzer
Lightbulb
Same with both our 2017 and 2019.
Regards,
Jim / crewzer
Old May 18, 2020 | 05:30 PM
cattaco's Avatar
cattaco
Yeah, they suck. I can't wait to break mine off and watch it slide slowly down into my oil pan.
Old May 18, 2020 | 07:12 PM
powersrp's Avatar
powersrp
Just make sure there is lube on that stick before you shove it in. 🤓
Old May 18, 2020 | 08:23 PM
Iraqvet05's Avatar
Iraqvet05
The 3' long dipstick on an LMTV/MTV is the dumbest I've seen...
Old May 18, 2020 | 09:34 PM
jollyrogr's Avatar
jollyrogr
Originally Posted by Iraqvet05
The 3' long dipstick on an LMTV/MTV is the dumbest I've seen... http://www.youtube.com/watch?v=g9gHFXql4KI
WTF? Check oil with the engine running?
I feel like the dipstick on the 6.7 is like 4’ long.
Old May 18, 2020 | 09:42 PM
Iraqvet05's Avatar
Iraqvet05
She was actually checking the trans fluid. The engine oil (just to the left) as also long as hell.
Old May 18, 2020 | 10:35 PM
Mikelikesit's Avatar
Mikelikesit
Yea a lot of older diesel trucks had 2 add lines. One off and one with engine running. There was a time when shutting some of these engines down in winter was rarely done.
messymom
Jan 30, 2015 04:36 PM
airsoft1779
Nov 30, 2013 08:25 PM
miket54
6.7L Power Stroke Diesel
26
Nov 25, 2011 06:02 PM
I6power
Oil & Lubrication
Apr 5, 2007 10:21 AM
Awsum77
Mar 12, 2005 03:47 PM
