Supercab Flipout Windows???
Old May 17, 2020 | 08:45 PM
Project King's Avatar
Project King
I’m restoring a 75 Supercab with flip out back side windows. Installing glass time. Both sides the top hinge post is solid and he bottom wiggles, is this correct? Should they both be solid? How do you install ? Put the plastic hinge on the post and then push the glass assembly in the cab? Any trips or tricks on installing?
Old May 18, 2020 | 01:19 AM
broktruk's Avatar
broktruk
You’re installing them correctly. There’s a little bit of a clip on both sides of the plastic where it retains itself on the inside of the pillar. If these are used pieces then the sharpness of the retainer is usually gone through removal process. If you have one loose you should replace it. When you take the window out again you might hurt the one that is tight.
I looked recently and found either JBG, NPD, or Dennis Carpenter had em and around $11 ea. Recommendation, get new and they will be tight and not leak.
Old May 19, 2020 | 12:01 AM
Project King
Are the hinges suppose to wiggle? Both sides the bottom do???
Bluey Zedoff
19
Apr 3, 2016 08:28 PM
hjoe
Nov 4, 2007 11:26 PM
GreatNorthWoods
Sep 1, 2005 10:29 AM
soundbeaches
1978 - 1996 Big Bronco
Apr 22, 2001 11:21 AM
