Sponsored by: Real Truck
One u-joint spins, other doesn't
Old May 16, 2020 | 04:54 AM
F550 6.0's Avatar
F550 6.0
1999 f450 7.3 manual hubs. With hubs unlocked I can spin the front axle by hand and the drivers side spins freely but passenger only spins about one turn then stops. My mechanic says it is normal.
I have searched all over, if there is a thread I missed please post the link.
I had a significant jump to the right two weeks ago in 2wd, got under the truck and noticed this. Locked the hubs and truck drove fine. They found a toasted hub on passenger side and replaced both. Day before yesterday I had the same jerk to the right, but they couldnt replicate the issue taking it on 4 test drives. They said u joints seem ok, they look super rusty and zerks appear ungreasable.
Thoughts?
Old May 16, 2020 | 08:38 AM
WWR's Avatar
WWR
Hmmm... well lots going on here. First, if a lockout (ie locking hub) is truly unlocked you should be able to spin the shaft indefinitely, BUT really a better test would be elevate that wheel, hold the shaft and spin the tire. Some slight resistance can be normal in the side gears or lockout itself and if you're just reaching your fingers into the inner C and trying to spin the shaft you MIGHT not be able to provide sufficient force by hand.
Second, even if a lockout suddenly engaged while driving I don't see how this would cause the truck to pull. With an open diff (which you almost surely have) and t-case in 2hi that shaft could suddenly engage at 90mph and you really shouldn't feel anything....unless MAYBE the u-joint is seized or close to it.
However, external rust on a u-joint is meaningless and trust me, you want non-greasables - they last much, much longer, ironically
Without being there I don't know what to tell you....a sudden pull to the right could be a lot of things including bad shocks or steering stabilizer (if you had just hit an irregularity in the road), a questionable wheel bearing, ball joints, track bar or leaf spring bushings, drag link or tie rod, etc.
Old May 16, 2020 | 07:12 PM
99f350sd's Avatar
99f350sd
steering issues are usually a bad ujoint causing steering problems...Pull the axles and check them. Also make sure wheel is straight ahead and you should be able to turn the axle on both sides...Driveshaft might turn.
Lock the hub and turn the tire on each side by itself.
Old May 16, 2020 | 10:40 PM
crusty old shellback's Avatar
I had a bad caliper that cause a similar issue. But I'd also get a death wobble once it got hot. Then it would pull right when brakeing. Bad left caliper.
Old May 17, 2020 | 04:45 AM
F550 6.0's Avatar
F550 6.0
[/QUOTE]First, if a lockout (ie locking hub) is truly unlocked you should be able to spin the shaft indefinitely, BUT really a better test would be elevate that wheel, hold the shaft and spin the tire. Some slight resistance can be normal in the side gears or lockout itself and if you're just reaching your fingers into the inner C and trying to spin the shaft you MIGHT not be able to provide sufficient force by hand.[/QUOTE]
Huh, so the tech was incorrect that "it's normal" for one to not spin. As there are brand new hubs in there now, and are both unlocked, why would one not rotate? Thanks for the replys. Did some driving yesterday towing a trailer on dirt roads and the highway with zero pulls btw.
Old May 17, 2020 | 08:21 AM
WWR's Avatar
WWR
If one shaft is truly not spinning free of the wheel hub, the lockout is either defective or not properly installed.
If the t-case is actually not in 2hi or not disengaging the front driveshaft output this might also make a shaft harder to spin by hand
With the truck in P and 2hi and weight on all 4 wheels, try rotating the front d/s by hand. It should turn and you'll probably observe ONE axleshaft turn ('tis the nature of open or peg leg diffs). Jam a screwdriver in the side that spins and try again, then the non-jammed side should spin. If it does, this tells you both lockouts are FREE because you were able to spin both shafts while the wheels/tires didn't move an inch
Old May 17, 2020 | 12:44 PM
99f350sd's Avatar
99f350sd
What he said! That's a good way to do it. 👍
greenman0013
Feb 20, 2017 08:32 PM
rc81620
Aug 27, 2008 10:06 AM
earlybirds
Feb 3, 2007 01:33 PM
sparky69
Offroad & 4x4
25
Jan 2, 2006 05:04 PM
muscletruck7379
Jun 16, 2004 05:55 PM
