88 f150 Cab swap Questions
Old May 15, 2020 | 10:27 AM
Gabcar8321's Avatar
Gabcar8321
Hey Everyone, so i am finally getting around to “restoring” my old 88 f150 w/ 4.9L ext cab w/ automatic trans. That gramps gift me. Last time i posted i wanted to swap a 4.6 and do a whole bunch of wild things to it, but i have matured a bit im keeping it stock.
I’ve inspected it last week and came to the conclusion that i need a new cab. My roof has a couple of holes, the a-pillars look like swiss cheese, and whole bunch of little places like door sils and cab corners. (I will insert a few Pictures.
I can easily get a new cab, I’ve got a few candidates. My question is, how hard of a job is it for a 18yr like me to swap the cabs over, and what legalities will i run into? I’ve found 90-91 cabs
thanks in advance, all input will be appreciated
Drivers side pillar
Driver’s side a-pillar
Drivers side rear window
Passenger side rear window
Old May 15, 2020 | 11:03 AM
Diesel_Brad's Avatar
Diesel_Brad
Wow, the cab is JUNK
To make things as easy as possible, I would get a 87-91 cab. Doesnt matter f150-F-superduty.
You need to remove the fenders, unplug the harness, steering linkage, shifter linkage, etc, then unbolt and lift off(if you take seat out and doors off it cuts down on weight quite a bit.
Depending on what truck the cab from you may be able to retain your cab harness and such, but I would just gut the new cab and reuse all your good old parts
As for "legal" that varies by state. Some states say when you do this you need to use title from the cab being used. But that make absolute zero sense to me because if you are putting aF350 cab on a f150, that does NOT make it a F350.
Other states want to see the original title and the cab tideland they will issue you a NEW title as in a 2020 title, again makes no sense since you have a 88 truck, Not a 2020.
But here is what I recommend. Put the cab on, remove windshield, drill out vin tag from your old cab and put in place on new cab. Also get a CLEAR pic of the door jam sticker, there are companies that reproduce them.
Then you have ZERO paperwork to fill out and you will still have your original vin for your 88 truck
Old May 15, 2020 | 12:45 PM
tjc transport's Avatar
tjc transport
i ain't rite
Depending on what the cab cab from you may be able to retain your cab harness and such, but I would just gut the new cab and reuse all your good old parts
this is what i have done many many times. here in New Jersey when you buy a cab you get it stripped. no doors, no glass , no wiring, AND NO VIN PLATE OR TITLE.
you have to use your old vin plate and title.
Old May 15, 2020 | 01:14 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Same here. Ford has always offered current year cabs as a replacement part. No different than changing a fender. Reuse your existing VIN plate and get a new decal printed. BTW, there is also a cowl tag by the brake booster held on with a single screw. Don't forget that one.
To make it easy, look for an 87 to 91 gas engine donor. That way, all the holes will be the right shape and in the right place. Tunnel cover should come from your original truck.
Old May 15, 2020 | 10:28 PM
Gabcar8321's Avatar
Gabcar8321
Thanks for the info!
what company or person do you recommend to Reproduce the door jam sticker?
Old May 15, 2020 | 10:40 PM
Gabcar8321's Avatar
Gabcar8321
Stripped cabs? Really? What im doing is getting a whole entire truck because apart from the cab i need a whole fuel system, mines rusted out
Old May 15, 2020 | 10:44 PM
Gabcar8321's Avatar
Gabcar8321
thanks, i will keep the cowl tag in mind
Old May 15, 2020 | 10:45 PM
Gabcar8321's Avatar
Gabcar8321
Old May 16, 2020 | 05:19 AM
2dwoods's Avatar
2dwoods
Were do y'all go were people actually check the vin numbers at the dash ,swap the cabs it's an old truck nobody cares if the numbers match who looks
Old May 16, 2020 | 06:31 AM
tjc transport
i ain't rite
Police, DOT, and Motor Vehicle Inspectors care. and if the vin does not match, they can impound the truck.
Old May 16, 2020 | 10:35 AM
Diesel_Brad
Officially licensed by ford
ECS Automotive Concepts - Late Model Replacement VIN Door Decals
Old May 16, 2020 | 11:08 AM
Eddiec1564's Avatar
Eddiec1564
Here in Florida the cops WILL look at the rivet heads of the dash vin. They are a special head and if tampered with, your going to hate life afterwards...(seen it happen few times). So do not drill out those rivets but grind off the back ends and use some windshield urethane to glue it back down(messy windshield installer....lol) and your good to go.
Ouch on the replacement B piller stickers $125 each! Need one for my 84 F250 after its cab swap.....
Old May 17, 2020 | 07:57 AM
Diesel_Brad
I paid $90 for my last sticker
Very easy to rivet tag on. triangular file pit the marks right in the head
Old May 17, 2020 | 09:28 AM
Gabcar8321's Avatar
Gabcar8321
Thank you!
Old May 17, 2020 | 09:30 AM
Gabcar8321's Avatar
Gabcar8321
Im in Florida too,(south florida to be exact)i will do some more research around here and I’ll see what i will end up doing.
