Towing capacity
Old May 15, 2020 | 09:20 AM
Bearchiasson's Avatar
Bearchiasson
Towing capacity
I'm trying to figure out what my payload and towing capacity is for a 2017 5.0 4x4 vin# 1FTEW1EF0HKD44046
Old May 15, 2020 | 09:47 AM
jyarosz's Avatar
jyarosz
The way I read the hitch specs you have a 5k tow rating and a 500 lb tounge weight rating..
Old May 15, 2020 | 09:52 AM
ford390gashog's Avatar
ford390gashog
To figure out payload you weight the truck, the payload sticker on the door will get you close.
Old May 15, 2020 | 10:58 AM
Robbgt's Avatar
Robbgt
Googling that vin, looks to be This Truck here. As mentioned, your yellow sticker will get you close to payload. The best method is to weigh the truck and subtract from your GVWR of 7,000
What I was able to gather from the photos/description:
  • SCrew 145" WB Truck
  • 5.0 & 4x4
  • Axle code 27 = 3.31 gears
  • The description states "tow package" - That could be:
    • If equipped with tow package is 53B (Medium duty tow package) then your tow capacity if 5,000lbs
    • If equipped with tow package 53A (HD Tow package) then your tow capacity is 8,900lbs. Keep in mind above 5k, you need a weight distribution hitch.
    • Above per the towing guide here
    • Payload is quickly consumed by Trailer tongue weight and needs to be accounted for.
  • Wheels/ tires are a wildcard, I can not speak to the carrying capacity of either
RedRaiderFan
All Things Towing
Sep 13, 2015 09:18 PM
Rickyrobert
2009 - 2014 F150
Apr 5, 2015 04:06 PM
ktf71096
19
Aug 18, 2013 08:52 AM
Jarniscipus
Feb 20, 2011 01:01 AM
wresleu
Mar 30, 2004 05:23 PM
