A/C condenser
Old May 14, 2020 | 08:05 PM
dmag67's Avatar
dmag67
A/C condenser
I have a factory A/C on my 73 F250 and recently installed a new compressor and evaporator coil. I bought a new condenser but it is nowhere as sturdy or built as well as the original. Would it be possible to reuse the original condenser with a new dryer? Or is it not worth the risk.
Old May 14, 2020 | 08:08 PM
caravaggio2000's Avatar
caravaggio2000
If you aren't running r12 you probably need a larger one than stock, at least that is what I was told.
Old May 14, 2020 | 08:12 PM
dmag67's Avatar
dmag67
As far as I can tell there is no difference size wize. Just the guage of metal.
Old May 14, 2020 | 08:59 PM
caravaggio2000
Yours can be rebuilt. You might be able to get away with the stock size in Kentucky. Here in FL, I need all I can get.
You could call Vintage Air. Measure how much space you have, tell them what you have and they will have the right one for you.
Old May 14, 2020 | 09:35 PM
dwirth's Avatar
dwirth
Comb it out and make sure it’s clean and use it
Old May 14, 2020 | 11:20 PM
Jetfixer-6's Avatar
Jetfixer-6
The old style tube and fin condensers are much beefier and are available for $120 on eBay. But if you have switched over to r134 with the new compressor then you need to upgrade to a parallel flow condenser as the tube and fin don't fare well with the higher pressures from R134. The advice from all aftermarket air suppliers is your condenser should cover as much of the core of your radiator as possible.
Old May 15, 2020 | 04:54 AM
Mark8man's Avatar
Mark8man
If the original is not physically damaged Have it flushed and it will be fine. I always opt for original when it comes to condensers and evaporators. New stuff just isn’t made as well and sometimes doesn’t fit as good. Remember to add the appropriate amount of oil. Typically the compressor will come with the amount of oil It normally holds assuming only compressor is being changed but each component also holds a certain amount of oil that must be accounted for. Replace expansion valve also. Lastly I’d run R12 but if going to 134 the hoses and lines should be flushed out as well to remove the old oil. A special flushing agent and flush gun is required.
Old May 15, 2020 | 06:21 AM
dmag67's Avatar
dmag67
Thanks for the help!
Old May 15, 2020 | 11:17 AM
HoustonDave's Avatar
HoustonDave
Re the flushing, we used 90+% alcohol through the lines and evap, no special fluid or gun. I replaced the dryer, condenser, and compressor. Make sure to run a good vacuum to make sure all the alcohol evaporates out.
HoustonDave
Sep 1, 2015 02:52 PM
73Custom
May 6, 2006 11:19 AM
73Custom
Aug 11, 2004 10:17 AM
Vin Man
Jul 26, 2004 12:24 PM
Haze
Sep 5, 2003 03:53 PM
