Diagnosing Drivabilty Issue
Old May 14, 2020 | 11:24 AM
Nicholas Fluhart's Avatar
Nicholas Fluhart
Hello. I recently bought a 94.5 PSD with 167k miles and 5-speed. On the way home it lost power and died. Diagnostics indicated the computer failed. I installed a reman computer and fixed it, but it slowly developed an issue where the first 50% or so of the throttle pedal was unresponsive. I took it in and had the computer flashed for OBDII protocol and the latest updates. It ran perfect for weeks after that. Now it has developed an intermittent issue where it cuts out under a light load or while trying to maintain a constant speed. When this happens, the cruise control does not work. Clears up under acceleration. Idles smooth, but the miss will manifest when holding high RPM in neutral. There is no smoke, except a little bit at cold start. There is no CEL and no codes present. Live data is all within normal perimeters. Injectors passed buzz test. High pressure oil is good. Fuel pressure is good. I have replaced ICP, IPR, valve cover gaskets and unhooked the fuel heater. Could it be injectors?
Old Jun 14, 2020 | 12:19 PM
Nicholas Fluhart
These forums are dead. I guess everybody is on the Facebook groups.
Anyway, I finally got this solved. Turns out there were two issues. The intermittent stutter issue ended up being the TPS. Didn't catch this immediately because the voltages showed to be normal when reading the live data. But we eventually noticed a very minor fluctuation under certain load conditions, even when the throttle itself was at various positions. Stuck a new TPS on it and no more problems. It ran great except the cruise still didn't work. So after testing, metering, probing most all the components in the cruise circuit (aside from the ABS) I found that the "ON" side the ON/OFF switch wouldn't measure anything on my meter. I took the switch out and carefully disassembled it and determined the contact prongs on the ON side were fatigued so I bent them upward slightly. Switch then metered good and the cruise works like a new one.
So two things I learned: The TPS can cause problems beyond the common dead or spotty throttle issues that I've read about. Also learned that the non-serviceable cruise buttons can actually be serviced if you carefully disassemble them. So glad to get this thing lined out. Nothing is more frustrating than weird, intermittent problems.
Old Jun 14, 2020 | 12:57 PM
Coralyns97's Avatar
Coralyns97
What brand tps did you use? I get CEL with Dorman brand
Old Jun 14, 2020 | 02:20 PM
Nicholas Fluhart
Dorman is all I could get immediately. So far it's doing great.
fyrehose
Apr 9, 2017 04:48 PM
Jumbo131
Jul 23, 2013 09:17 PM
Crewcab Turbo
22
Apr 15, 2013 10:36 AM
thumper15
Jan 30, 2006 10:14 PM
95f1504x4
Oct 8, 2002 09:25 PM
