Pinion torque
Old May 14, 2020 | 08:52 AM
Buckley's Avatar
Buckley
Pinion torque
Does anyone know the proper pinion torque on a 66 m250 Dana 70 rearend
Old May 14, 2020 | 09:06 AM
TA455HO's Avatar
TA455HO
Lead Gopher
You sure that's a Dana 70? The F350/M350 came with Dana 70 and F250/M250 should be Dana 60.
Regardless the Pinion Shaft Nut should be 250-270 ft-lbs.
If you are instead asking about Pinion Bearing Preload that would be
Dana 60: 10-30 inch lbs.
Dana 70: 10-25 inch lbs.
PJ-Hunter
Dec 7, 2015 09:15 AM
gearshift101
Oct 5, 2006 09:23 PM
zomowiec
Sep 25, 2006 04:45 PM
truck35
Feb 18, 2003 12:38 PM
