Sponsored by: Real Truck
LED tail light issues
Old May 12, 2020 | 12:14 PM
hotrodford_88's Avatar
hotrodford_88
I have an 05 F250, I’ve added a ranchhand bumper and headache rack with al LED lighting, and for some reason after adding the replacement led bulbs to the factory taillights I now get feedback whenever I turn on the emergency flashers. It will actually flash the dash lights inside. But that’s not all, it messes with my trailer lights as well. Turn on the left turn and the markers and the entire trailer flashes (and the grounds have been checked.) swapping back to an incandescent fixes the issue but I’d rather have the led.
anyone have an idea I might try? Resistors aren’t helping either.
Old May 12, 2020 | 02:48 PM
Mac Daddy's Avatar
Mac Daddy
LED compatible flasher?
Old May 12, 2020 | 02:58 PM
hotrodford_88
Yes, sorry I forgot that detail. It is a heavy duty electronic.
Old May 12, 2020 | 03:24 PM
moymurfs's Avatar
moymurfs
Is Heavy Duty Electronic the correct flasher? When you put Led in you are lessening the load. I put replacement led bulbs in my tail lights and front turn signals. The only thing I needed was a standard load flasher that was led compatible. I pull a a couple of different trailers and they all work fine. (2006 f250).
Old May 12, 2020 | 03:34 PM
hotrodford_88
I used the EP27 electronic replacement for our trucks and rated for all led or a mix.
kameronth
Electrical Systems/Wiring
Mar 7, 2008 05:22 PM
nvreloader
All Things Towing
Mar 5, 2007 09:09 AM
rebel_ford4x4
All Things Towing
Nov 12, 2006 10:32 PM
fang180
Dec 31, 2004 12:41 AM
underDAWG
13
Apr 19, 2004 04:19 PM
