Side warning/marker lights
Old Mar 4, 2007 | 05:28 AM
nvreloader's Avatar
nvreloader
Is there a simple way to make the side clearance lites on long trailers flash the same as the rear turn signals. This might wake up stupid drivers so they take notice that your are turning to the right and don't pull between the trailer and curb.
They don't seem to take notice that the turn signals are working, indicating your intentions to make a right turn.(worst side) I plan on getting two of those arrowed turn signal lites and swapping out the clearance lites in the middle of the trailer.
There has to be a simple way of showing that you are turning right, while leaving the enough room to make the corner.
Any thoughts or ideas?
TIA
nvreloader
Old Mar 4, 2007 | 05:32 AM
whittaj2003's Avatar
whittaj2003
I'll be following along with this one. I have the same problem and would love to get the side marker lights working as turn signals.
Old Mar 4, 2007 | 05:50 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
The problem with this one is that the power for the side markers is from the headlights circuit and the turn signal is attached to the brake light. You would have to use a small brake light with a dual filament lamp (one for marker and the other for brake). Most of the ones I've seen stick out a ways and would be ugly and would have a tendacy to get broken off. Great idea though. Or you could attach another side marker light under the current marker and wire it to the turn signal circuit.
Old Mar 4, 2007 | 09:26 AM
jorlee's Avatar
jorlee
http://www.pmlights.com/products.cfm...fId=3&pId=1451
http://cgi.ebay.com/ebaymotors/Semi-...1676QQtcZphoto
Marker lights are not meant to be used as turn signals. They just aren't bright enough.
What type of trailer is this anyhow?
Old Mar 4, 2007 | 09:32 AM
Fishsimion's Avatar
Fishsimion
Here are some LED lights that are side markers and double as turn signals.. They show them flashing in the pictures..
http://cgi.ebay.com/ebaymotors/led-Y...3087QQtcZphoto
Old Mar 4, 2007 | 12:30 PM
westtntrucker's Avatar
westtntrucker
I am an over the road truck driver. On my semi i have 4 turn signals down the side of the truck, Rear of trailer, middle of trailer, back of tractor, on front fender that faces the rear. I still get stupid people that try and cut up the side when i swing wide to make a right turn. No amount of lights will cure stupidity.
Old Mar 4, 2007 | 02:15 PM
bigredtruckmi
Veteran: Navy
Yes I crushed one trying to do a right when I was doing a wide right. Didn't do their hood much good.
Old Mar 4, 2007 | 03:32 PM
albran's Avatar
albran
Somebody needs to catch me up on trailer lights (it's been a LONG time).
Won't you need a new wire from the brake/turn signal to each side marker location?
and then when you step on the brake won't the new side lights light up?
Old Mar 4, 2007 | 03:57 PM
bigredtruckmi
Veteran: Navy
Your correct on the hookup.
Old Mar 4, 2007 | 06:11 PM
nvreloader's Avatar
nvreloader
Thanks guys,
I found this info and it appears that it might???? work.
http://www.danielsternlighting.com/t...rkerflash.html.
Being that I am challenged in this area, how about giving this articule the once over and providing your thoughts, there has to be something more a person can do!
TIA
nvreloader
Old Mar 4, 2007 | 06:52 PM
jorlee's Avatar
jorlee
It does work. I did that to the front corners of my 2001 Ranger. Would flash at the same time when headlight switch was off. Would alternatly flash when the park or headlights were on. Only downside to it is the marker lamp is now dimmer, since it doesn't go directly to ground, but goes through the filament of the turn signal bulb to ground.
Adding a flashing marker light won't be enough for them to see, would be best to add a actual turn signal, made for trailers.
Old Mar 5, 2007 | 09:09 AM
Sycostang67's Avatar
Sycostang67
I did that to my truck as well, no problems with it at all. At least it's an option, and it's reversible if it doesn't work the way you want it to.
