Sponsored by: Innova
Explorer 94 premium sound problem
Old Oct 16, 2003 | 10:27 PM
ddsnaggle's Avatar
ddsnaggle
I recently bought a 1994 eddie bauer explorer with premium sound included and wanted to put in an aftermarket head unit. I bought the harness that was made to fit the factory sound wiring and I thought everything would work out fine. However when I power up the cd player it seems to function however I get no sound whatsoever. I know the deck works, I pulled it and tested it in another car. I was thinking it would have to be a problem with the factory amp that is in the truck. I then bought a wiring setup that would connect to the speaker wiring to the pre-amp outputs on the head unit. This did not work either. I thought after the first attempt that the power from the deck was shutting the amp down, but now after using the low level signal from the pre-amp outputs on the deck and having no success I'm stumped. I don't want to wire around the factory amp but I'm runnign out of ideas. So I need help with two things 1- how can this deck work with the factory amp. 2- can I use the amp in some way if I wire around it, for a sub. I have seen the amp eliminator plug out on shelves but don't want to spend more money on something I don't know will work. Any thoughts would be helpful this point.
Old Oct 16, 2003 | 11:51 PM
mzimmers's Avatar
mzimmers
What kind of outputs to the amp did the original head unit have? What are the input options on the amp? Is there a switch on the amp telling it what kind of inputs to expect? Have you put a voltmeter on the pre-outs of the new head unit to ensure that signal is indeed coming out?
Old Oct 17, 2003 | 12:04 AM
ddsnaggle's Avatar
ddsnaggle
I found out that the amp needed a 5 volts of power, which I fed by the power antenna. It worked great right up until I shoved the cd player in and saw a spark. The power wire hit the hu cage and zaped the deck. Talk about a bad day, all that work to blow the deck I was gonna use. Oh well, I wanted an mp3 player anyway. Thanks for the help though, I'm sure you'll get a laugh out of that story of my stupidity.
Old Oct 18, 2003 | 06:36 PM
91ExploXLT's Avatar
91ExploXLT
when you bought the wire harness did they tell you that you needed to buy the amp bypass plug? if they didnt you need to buy it just go to a store where you can get incar cdplayers and such and ask for the amp bypass plug i had to when i put my cdplayer in. and the Amp is behind the pannel over the rear right tire if that helps
GucciSock
Sep 18, 2023 10:58 PM
SCREW
6.7L Power Stroke Diesel
Oct 13, 2015 12:16 PM
JefFZ6
1983 - 2012 Ranger & B-Series
May 25, 2008 11:23 AM
ktplotts
Aug 29, 2005 01:18 PM
breakdxwns
Nov 19, 2004 09:23 PM
