1966 - 1977 Early Broncos
Carb issues?
Old May 10, 2020 | 09:34 PM
Rcbronco8's Avatar
Rcbronco8
Carb issues?
76 Bronco. I had a Edelbrock carb and engine was shutting down from idle to gear or coming to stops. Tried many things before changing to a brand new Holly carb. Ran great when first changed and now it’s doing the same. Changed the ignition modular. Fired right up, ran good, then same issue again.
Looking at utube, trying to self teach...messed with idle again didn’t help. I can play with Vacuum valve I guess, but it’s a brand new carb and I am a rookie greenhorn when working with engines. Any help or resource videos please?
Old May 11, 2020 | 10:42 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Classic Bronco is a much busier forum, I mean we all try to help as much as possible. But we are not at the level of exposure to Bronco owners as that site.
Are you sure the fuel pump is good? Any inline fuel filters? Is the tank clean, pick up tube filter sock installed?
Air....fuel....fire (elec). The big 3 to check.
https://classicbroncos.com/forums/index.php
Old May 11, 2020 | 11:09 PM
Rcbronco8's Avatar
Rcbronco8
Thanks. Yes, new fuel filter. I believe it to be Intake gasket
Old May 11, 2020 | 11:11 PM
77&79F250's Avatar
77&79F250
If you have a large vacuum leak, yes it will run like crap. What type of 4bbl intake do you have on it? Aftermarket aluminium or ?
Quammer
Mar 9, 2020 09:53 PM
72tank
Jun 21, 2006 11:59 AM
Dirt Head
Mar 15, 2006 11:05 PM
bassmanh
Apr 13, 2004 07:33 PM
Scrapiron66
Feb 6, 2004 05:54 PM
