Noisy Altenator
Old Oct 16, 2003 | 09:59 PM
Marine's Avatar
Marine
Noisy Altenator
I have a '68 F100 with an '85 302. The altenator was completely covered with dirt, grease, and grime. Before I removed it for cleaning, I stopped by Advance Auto and had them test it and the battery. Both checked out perfect!!!
I removed the altenator and take a wire brush to it and got it all nice and shiny. I even used my air compressor to blow out the dirt from the inside. The bearing feels tight, however, it makes a little noise when I spin the pulley. I believe the previous owner let it sit outside without the hood on. Rain probably got in it, plus a little water from my garden hose.
My question is: Will I ruin the altenator if I sprayed a little white grease or WD-40 on the bearing? Will it ruin the altenator if I sprayed some inside of it?
Thanks for any advice!
Marine
Old Oct 17, 2003 | 12:43 PM
Franklin2's Avatar
Franklin2
The bearings are sealed, so spraying them is not going to help. I would not recommend spraying anything inside it, since there are brushes and slip rings which could get contaminated.
Old Oct 17, 2003 | 12:56 PM
Mike W's Avatar
Mike W
Get a kit for it. It comes with a new bearing. It is probably filthy inside. Before you spend a lot of time on it, look at the slip rings. If they have deep groves, just get a rebuilt unit.
Old Oct 19, 2003 | 09:21 AM
brewster's Avatar
brewster
I would just go with a rebuilt one . I just picked one up for $38.99
all rebuilt. It is a 60 amp ALT.
Brewster
Old Oct 19, 2003 | 10:44 PM
Marine's Avatar
Marine
I sprayed a little white grease on the shaft directly behind the pulley. That seems to have done the trick for now. I appreciate all the feedback!
brewster - where did you find a $39 rebuilt? I can't image Autozone or Advance Auto at that price. I could be wrong though!
Old Oct 20, 2003 | 05:52 PM
brewster's Avatar
brewster
I got mine at fleet farm store. Don't know if you have one were you are . I would think you can get one for that price at auto zone. The alt I have has a external voltage regulator.If you have the internal reg in the alternator they cost like $100 to $ 150
Brewster
MNchadwick
Dec 4, 2018 09:24 PM
stone3663
Sep 4, 2010 10:10 PM
61 uni
Apr 15, 2009 09:53 AM
blairlogan46
1997 - 2003 F150
Dec 4, 2005 04:30 PM
poffutt
1978 - 1996 Big Bronco
Aug 23, 2005 11:07 AM
