Squeal When Downshifting Under Load
Old May 9, 2020 | 10:49 PM
Nathan_FM's Avatar
Nathan_FM
I was towing a 4000 lb load a few days ago on the interstate, and when going 70 mph up a hill, the trans shifted down, so my revs went from ~2000 to ~2700. This resulted in a high pitched squeal from the engine that lasted for several seconds and then died away. My first thought was this was from the fan clutch, but I was hoping someone has had the same symptoms, and could recommend the cause?
Old May 10, 2020 | 09:31 AM
oharal's Avatar
oharal
The belt is slipping, probably on the fan. Watch your belt tensioner and see if it's bouncing around at idle and if a helper revs the engine. It's probably bad. Think mine is on the way there as I get the same symptoms from time to time.
Old May 10, 2020 | 12:16 PM
jstihl's Avatar
jstihl
https://www.ford-trucks.com/forums/5...belt-prob.html
the second Post in this link may help you. Ford made a slightly smaller belt for this problem
Bigfront
17
Feb 23, 2022 08:01 PM
Courtney Williams
Aug 1, 2018 04:41 PM
blakec
Jul 22, 2009 07:46 PM
Ashby
Jul 27, 2008 01:51 PM
