Bad fan clutch?
Old Jul 21, 2008 | 09:08 PM
Ashby's Avatar
Ashby
Bad fan clutch?
2000 7.3 Excursion.
SO I have never seen my fan not run. Even on cold start up it spins. I have recently started to have a squeal from under the hood. I have swapped put the tensioner and pulleys with no avail. If I spray belt dressing on the belt the noise goes away for awhile. The belt looks just fine. I can turn the fan when the truck is off but it is feels like it is kinda dragging. Any thoughts....Two weeks to Sturgis.
Old Jul 22, 2008 | 01:27 PM
Ashby's Avatar
Ashby
Bump to the top
Old Jul 22, 2008 | 04:27 PM
FordxFour's Avatar
FordxFour
Are you sure the belt hasn't dried out?
Old Jul 22, 2008 | 05:52 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is it a regular clutch fan like they have on the gassers?
If so, it should drag a bit when the engine is shut off, and it WILL spin when the engine is running.
Does it make a roaring sound when your driving around ? If not, no worries
Old Jul 22, 2008 | 08:22 PM
Monsta's Avatar
Monsta
Sit. Stay.
Go buy a new belt.
Old Jul 23, 2008 | 12:20 PM
Ashby's Avatar
Ashby
But isn't the fan not supposed to turn when the engine is cold?
Old Jul 23, 2008 | 12:29 PM
FordxFour's Avatar
FordxFour
The fan will turn when cold, but it is actually freewheeling, as the engine heats up the clutch engages and loads the fan.
Old Jul 26, 2008 | 12:23 PM
jesterdog's Avatar
jesterdog
Originally Posted by Monsta
Go buy a new belt.
I second that...
Old Jul 27, 2008 | 01:51 PM
Ashby's Avatar
Ashby
Well I put a new gatorback belt on it and all seems well. I drive it about a hundred miles yesterday and no noise. Hopefully it won't come back on the way to Sturgis. Thanks for the help!
Big Skier
31
Feb 27, 2019 07:21 AM
GB SISSON
Mar 13, 2014 03:04 PM
rog2000
Feb 22, 2014 02:46 PM
fireguy L29
Feb 2, 2007 07:32 PM
hawk41
Aug 11, 2004 07:32 PM
