Camshaft sensor location
Old May 14, 2020 | 06:14 PM
Mzupp's Avatar
Mzupp
I will get the fuel psi. My OBD1 system is not working, not pulling any codes.
Old May 14, 2020 | 06:55 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Thats not good. Defective computer?
Old Jun 11, 2020 | 06:06 PM
Mzupp's Avatar
Mzupp
So it has taken me some time to get back. The PSI on the engine is good 120-122 at each cylinder. Replaced both fuel pumps and sending units, starter. Since replaced the started, don't know if its related but there is a low crank, then I need to turn the ignition 3-4 more times to start the engine. Runs pretty well after that but I feel something is holding the engine back from increasing speed above 35/45 mph. Any thoughts would be appreciated.
Old Jun 11, 2020 | 06:53 PM
My4Fordtrucks
Clogged catalytic converter?
Old Jun 11, 2020 | 07:39 PM
Mzupp's Avatar
Mzupp
Thanks for the reply, any additional information as to why you think it might be a clogged catalytic converter would be appreciated.
Old Jun 11, 2020 | 09:19 PM
Gee150's Avatar
Gee150
I would also give it a good dose of fuel injector cleaner as it's been sitting idle. Techron will do if you cannot get BG 44K. Some simple basics first. Check the vacuum system. Also make sure you know how to change the PIP sensor if you decide to go that way. It has to be pressed on and off the distributor shaft.
What do you mean exactly when you say your "OBD1 is not working, not pulling any codes"? How are you testing for codes?
marcrex
Oct 21, 2019 08:18 AM
crew1
2015 - 2020 F150
Jun 10, 2018 08:39 AM
