Need help finding transmission
Old May 5, 2020 | 09:38 PM
74ford100's Avatar
74ford100
I’ve got a 1974 f100 360 fe with the stock automatic transmission and I want the switch to a manual transmission. I’m having trouble finding name of the stock manual transmission. I was also wondering about doing a 5 speed transmission swap but couldn’t find one that says that it’ll fit my motor. Does anyone know the name and model of the stock manual transmission or the name of a 5 speed aftermarket trans that would fit my truck?
Old May 5, 2020 | 09:51 PM
440 sixpack's Avatar
440 sixpack
The Np435 was used on all the Fords of this vintage I've seen. maybe F100's are different but an NP435 will work for you.
I'm not aware of a 5 speed that works on the FE but I could get one in my high boy I'd do it.
Old May 5, 2020 | 09:56 PM
ford390gashog's Avatar
ford390gashog
There is plenty of information here on for this swap. Because there is no stock option and you are willing to go aftermarket then the TKO600 will work just fine.
Old May 5, 2020 | 10:06 PM
440 sixpack
I forget all pickups aren't 4x4's. it's not an option on them.
Old May 6, 2020 | 07:36 AM
FuzzFace2's Avatar
FuzzFace2
If looking for an over drive to use with either the auto or stick there are 2 to pick from unless auto then only 1.
Advance Adaptor Range Splitter - stick only and can be used in 4x4
Gear Vender - stick or auto cannot be used in 4x4
Dave ----
77’ f150
Dec 16, 2018 07:25 PM
flashflood08
Nov 6, 2012 09:16 AM
Bigjl
Mar 24, 2010 09:06 PM
byron74f100
Dec 14, 2008 07:10 PM
Raymond56
1983 - 2012 Ranger & B-Series
Sep 23, 2003 05:20 AM
