Carli Track Bar
Old May 5, 2020 | 07:37 PM
cattaco's Avatar
cattaco
Carli Track Bar
I was going to install my Carli Track bar and I noticed when I torqued down the gold jam nut it doesn't fully tighten flush. Anyone have a picture of their track bar installed or notice something similar. I didn't have a crow's foot to tighten it so I didn't have a torque wrench but I tightened it as tight as I could get it with a long adjustable wrench so it should be plenty tight. Thanks a lot.
Old May 5, 2020 | 09:10 PM
Stinson1's Avatar
Stinson1
Old May 5, 2020 | 09:41 PM
cattaco's Avatar
cattaco
Originally Posted by Stinson1
Thanks, not what mine looks like. I have probably a 1/16" gap. Don't know what to do now.
Old May 5, 2020 | 10:04 PM
SARDiverDan's Avatar
SARDiverDan
Track bar torque is over 400 Ft Lbs so you need a long cheater on your wrench or you need to take it to a shop and have it torqued properly. My torque wrench for setting 400+ Ft Lbs is 41” long.
Old May 5, 2020 | 10:06 PM
cattaco's Avatar
cattaco
The jam nut is only 200 ft lbs. To the frame is 400.
Old May 6, 2020 | 06:28 AM
Stinson1's Avatar
Stinson1
Give Carli a call and let them know what is going on. When I did mine a year ago the directions mentioned that this jam nut style was a new design. Maybe it is possible the taper machined into the end of the bar is not correct? Hope you get this sorted quickly. Everything with my kit was spot on.
Old May 6, 2020 | 11:36 AM
cattaco's Avatar
cattaco
Contacted Carli, they said that is how it's supposed to be. Said it's part of the design. I don't know why yours fully tightened and mine won't, maybe it's a different lock nut design again.
Old May 6, 2020 | 04:36 PM
SlikWillie's Avatar
SlikWillie
Post a picture. Let us see exactly what you are talking about.
Old May 6, 2020 | 08:46 PM
cattaco's Avatar
cattaco
Sorry for the poor lighting.
Old May 6, 2020 | 11:47 PM
digz's Avatar
digz
Carli is different than alot. It's not just a nut it has a taper that compresses on the threads. Way better imo.
Old May 7, 2020 | 07:15 AM
jwc410's Avatar
jwc410
Carli changed their design, you can read it on their webpage. The new design is fine.
Old May 7, 2020 | 07:28 AM
jbjones85's Avatar
jbjones85
That looks the way I have seen the newer ones look on their videos. I'm 99% sure it is supposed to be like that as it has tapered threads.
Richwon4
All Things Towing
May 6, 2020 08:44 PM
C_Smitty
Dec 2, 2017 05:35 PM
Imports2Domestics
13
Sep 7, 2013 10:09 AM
wolffee
Nov 1, 2012 11:42 AM
DAVE67FD
Mar 23, 2009 01:50 PM
