Trans Dipstick
Old May 5, 2020 | 07:43 AM
RGPolo's Avatar
RGPolo
Trans Dipstick
I want to install a Transmission Dipstick on my '19 F250 6.2. I'm sure it has been talked about here but I can't find any conversations, nor can I find info on finding an aftermarket unit. A few out there for F150, but don't see any for Superduty. Any help guys?
Old May 5, 2020 | 08:13 AM
6.2caribou's Avatar
6.2caribou
I searched 6r100 dipstick and a bunch of threads appeared. Below is the first on the list. In the thread it states that parts listed from a 17 my truck won't fit but it doesn't state why not.
https://www.ford-trucks.com/forums/1...-dipstick.html
Old May 6, 2020 | 08:27 AM
RGPolo's Avatar
RGPolo
Yeah, bummer. I don't know why the one for the f150 wouldn't work. Same cab and I thought the 6r100 was a beefed up 6r80. The only diff would be how the different motors fit in engine compartment. Damm things are too $ to just buy one to see if it works. $200 plus.
Old May 6, 2020 | 10:03 AM
longhaultransport's Avatar
longhaultransport
Ok you got me curious now.
Why do you want a dipstick?
Old May 6, 2020 | 11:35 AM
6.2caribou's Avatar
6.2caribou
I didn't look at the part #s source vehicle. Are they for a F150? My '17 has a dipstick and a drain plug in the pan. I just assumed that whoever researched the numbers did so for a '17-'18 F250. I've not yet seen the '19+ 6R100 mini dipstick, but if the transmission casting wasn't changed, I wonder why '17-'18 parts wouldn't work.
Call me old school, but why wouldn't I want to easily be able to check the trans fluid level? With all of the postings about things that are overlooked during manufacture and during dealer PDI and service I don't get why I wouldn't want to be able to easily check the trans fluid level. The check procedure for the mini dipstick looks to be a PITA if you don't have a 4 post lift.
Old May 6, 2020 | 01:50 PM
RGPolo's Avatar
RGPolo
I do all my own maintenance because I don't trust anyone else to do it. The dealers hire young "air heads" to do the minor things like fluid changes and I personally know of a few crooks in the independent shops. My 2019 dipstick is about 3" from the very hot catalytic converter...stupid, tough even for a Pro to check. Also you need to fill it though the same port. I'm Ford Trucks all in, but this move is ridiculous. I am also going to install a Pan that has a drain plug.
Old May 6, 2020 | 03:49 PM
Crabbman P's Avatar
Crabbman P
One reason if you ever get a leak while on the road. I had a Chevy while I was making a delivery I saw fluid dripping on the ground. It was a slow line leak but I had no idea how long it had been leaking. Pulled out the stick could not find any fluid on the stick. Stopped by a parts store and dumped some Dex VI in until full on stick and limped home. Without the stick would be clueless how much to add. It's also good for peace of mind to pull the stick occasionally and check levels, view oil condition. Call me old school as well but I'm glad my 18 has the dipstick.
Old May 6, 2020 | 05:49 PM
RGPolo's Avatar
RGPolo
Ah, maybe for the same reason I don't trust my Government, do you? Yeah, I am a conspiracy theorists. 10/4
Old May 6, 2020 | 06:43 PM
longhaultransport
OK, The trans is a closed system, but I can understand.
What about the diffs?
Old May 6, 2020 | 07:59 PM
Spaceman_Spiff's Avatar
Spaceman_Spiff
Old May 7, 2020 | 08:56 AM
RGPolo's Avatar
RGPolo
Originally Posted by Spaceman_Spiff
You misspelled Dip****s
Old May 7, 2020 | 09:43 AM
HRTKD's Avatar
HRTKD
The differentials are easier to check. "Easier" being understood within the context of access and risk of being burned by hot exhaust components.
Old May 7, 2020 | 09:45 AM
RGPolo's Avatar
RGPolo
10/4 on that
Old May 7, 2020 | 06:44 PM
h20camper's Avatar
h20camper
So looking at the 2020 Owner's Manual, it seems Ford removed the transmission dipstick on the new 10R140 too. Can anyone confirm that?
AUTOMATIC TRANSMISSION FLUID CHECK
The automatic transmission does not have a transmission fluid dipstick
Old May 7, 2020 | 06:55 PM
rocket_scientist's Avatar
rocket_scientist
Thought this thread was gonna be about Michelle Obama's new documentary on Netflix, but was disappointed.
Torinoman72
Jan 8, 2016 12:29 PM
$Simpleman76
6.7L Power Stroke Diesel
Apr 24, 2010 10:30 AM
bigfoot22
Jun 26, 2008 08:55 PM
kage87z
Oct 22, 2007 06:55 PM
kjg26
Oct 21, 2007 09:21 AM
