Trans Dipstick
Old Feb 4, 2020 | 08:46 PM
Craig in Appleton's Avatar
Craig in Appleton
Trailering
Trans Dipstick
Has anybody installed the dipstick HC3Z-7A22 tube and HC3Z-7A020D on their 2019 Super Duty? If so was there any problems?
Old Feb 4, 2020 | 10:01 PM
Mikelikesit's Avatar
Mikelikesit
Im interested in this too. Are those Ford Numbers?
Old Feb 4, 2020 | 10:08 PM
ford390gashog's Avatar
ford390gashog
The tube and dipstick can't be added with factory parts. You will have to go aftermarket if you really want it.
Old Feb 5, 2020 | 01:13 AM
Coops361's Avatar
Coops361
Is there really no dipstick on 19s? (I have a 17 with dipstick and drain plug)
Old Feb 5, 2020 | 03:46 AM
67L48's Avatar
67L48
I'm pretty sure my 2019 6.7L PSD has a transmission dipstick. I haven't looked for a drain plug on the transmission fluid pan.
Old Feb 5, 2020 | 04:30 AM
hogryder007's Avatar
hogryder007
I thought it was only the 10 speeds that didn't have dipsticks.
Old Feb 5, 2020 | 09:04 AM
Craig in Appleton
Trailering
Trans Dipstick
Yes those are Ford numbers from the website. From what I understand the diesel trucks have a dipstick for 2019 but not the gas trucks.
Old Feb 5, 2020 | 09:14 AM
Crabbman P's Avatar
Crabbman P
Only the 6.2 G100 tranny in the F250s lost the dipstick in 2019. The F350 on up with the 140 tranny still has one, as does the diesel.
Old Feb 5, 2020 | 10:21 AM
ford390gashog
Gas trucks with the 6r140 have a dipstick, only the 6R100 in the F250 has no dipstick. For 2020 no trucks have a dipstick unless it's a F650+.
Old Feb 6, 2020 | 06:56 PM
CJONE's Avatar
CJONE
If my.2020 has one i cant find it and.have been all over it. The oil dipstick is bad enough! Cj
Old Feb 6, 2020 | 09:07 PM
Craig in Appleton
Trailering
Trans Dipstick
I called B&M transmission, because the have dipsticks for the F150. None for the 6R100. If anyone knows of a good after market, please let us know. The factory numbers I posted will not work.
Old Mar 29, 2022 | 10:59 AM
WheelMan6's Avatar
WheelMan6
Was there ever a solution found to this? I have a 7.3L with a van style trans dip stick, which is a mile long and stretches out over the top of the engine. I'd prefer a shorter version, figured whatever the trucks had. Will the part numbers you posted in your OP work Craig? I see you said they will not for your application, but is that just space limitations, or actual part incompatibility? I've been searching for a solution to this, with no luck. Appreciate anyone who can help!
Old Mar 29, 2022 | 11:58 AM
jollyrogr's Avatar
jollyrogr
No dipstick on the new 10 speeds, 2020+
Old Mar 29, 2022 | 12:00 PM
WheelMan6's Avatar
WheelMan6
My apologies, I forgot to include that I have the 6R140 not the 10.
Old Mar 29, 2022 | 12:36 PM
redford's Avatar
redford
FTE Leadership Emeritus
So you have a 7.3L with a 6R140 transmission?
But, aside from that, the 6R140 district in my 2019 F-250 is also very long.
