96 manual swap
Old May 3, 2020 | 03:06 PM
Crimson_Gambler's Avatar
Crimson_Gambler
96 manual swap
Halfway through the donor 95 4.9 300 2x4. And coming into some issues. Can the engine wire harness and ecu for a 95 4.9 manual transmission be used for a 96 4.9 auto to manual swap. So basically just swap the ecu wire harness over to the 96 so the clutch sensors and speed sensor without without changing the body harness on the 96. The 96 is also 2x4 4.9 300
Old May 3, 2020 | 05:03 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Offhand I’d so no because the ‘95 should be speed density OBD-I while the ‘96 is probably mass air and OBD-II. What transmission is in the ‘96?
omallyman
Sep 6, 2018 06:09 PM
dizturbed
Aug 10, 2010 10:32 AM
Allbie16
1978 - 1996 Big Bronco
Apr 19, 2006 08:58 AM
