Stumpy's Stumped
Old May 3, 2020 | 11:30 AM
Spankey Stumps's Avatar
Spankey Stumps
Stumpy's Stumped
Ok so, my daily driver is a '93 3/4 ton F-250 and has a 4.9L 300i straight 6 in it that is about to give out on me. I just recently bought a '89 F-150 from a friend that needed a little help. Anyway it has a 5.0L V8 in it. Now both 89 5.0 and 93 4.9 motors are both EFI, my question is has anybody ever attempted to swap the 4.9 for the 5.0 and what do I need to do to do it and how hard is this gonna be since I'm already kinda half way through this swap lol.
Old May 3, 2020 | 12:21 PM
jas88's Avatar
jas88
Your biggest challenge is the wiring harness on the '89 will not plug into the '93. You will also need to put the motor mount perches from the 302 into the 300 truck.
Old May 4, 2020 | 12:08 AM
Spankey Stumps
Ok so is it possible to splice the plug from the 93 to the 89 harness? I mean would the colors of wires match land go to the correc5 terminal? Or would it be better to install the entire 89 harness into the 93?
Old May 4, 2020 | 07:36 AM
jas88's Avatar
jas88
My recommendation would be to obtain an engine harness from a 92-96 302 truck.
Old May 4, 2020 | 12:24 PM
jackietreehorn's Avatar
jackietreehorn
The 80's wire harnesses are pretty different. If you have unlimited time and enjoy pain, then by all means splice them together. Probably half the colors match and the other half are probably opposite.
Just swap the harnesses.
Old May 4, 2020 | 06:28 PM
torq'ta 5 8's Avatar
torq'ta 5 8
what trans will you use, that will also need addressed, when getting the ECM for a v8, instead of I6
here is pinout difference between the years, 92-newer had harness change
your 89 harness
your 93 harness
oldfordenthusiast
Engine Swaps
Aug 28, 2017 05:51 PM
93fseries
Mar 1, 2014 11:40 PM
mavman
Jan 10, 2001 04:52 PM
