7.3 IDI alternator
Old May 2, 2020 | 06:11 PM
JakeWens's Avatar
JakeWens
7.3 IDI alternator
Okay, so I’ve posted a few times on here and gotten a lot of great help, well, the alternator that came in my truck was bad. I ordered one from obb starters and alternators, one I’ve seen recommended in several YouTube videos and on some forums. But, mine came with the wrong pulley, and the wrong connections for my truck, are there any adapters so I don’t have to deal with cutting and splicing wires? Or do I just need to get an OEM replacement?
Old May 2, 2020 | 06:13 PM
ford390gashog's Avatar
ford390gashog
Would have recommended a 3g alternator if you were doing a upgrade. If you need a replacement large case 1g send me a PM and we can discuss.
Old May 2, 2020 | 06:44 PM
JakeWens's Avatar
JakeWens
I actually got a 3G, however the connectors on it are different. And the pulley that came on it doesn’t fit. I also can’t swap the pulleys without finding a soccer or something.
Old May 2, 2020 | 06:48 PM
ford390gashog
Okay well you need the 3g pigtail, new 4ga charge cable and a 150amp mega fuse or circuit breaker. The pulley swaps right over and split lock washer makes a good spacer and a little grinding on the front bearing ribs.
Skip Bonds
Apr 26, 2020 08:00 AM
ptm
Jan 18, 2014 09:10 AM
redneckfordman1
16
Jan 11, 2013 08:39 PM
tpinmanf375
40
Dec 26, 2012 03:29 PM
Rick2001
Nov 24, 2006 09:32 PM
