Drivers side spindle/kingpin
Old May 1, 2020 | 05:41 PM
Castaway71's Avatar
Castaway71
I have searched EVERYWHERE and no one can press new king pin bushings in my spindle and i cannot find a new one. Im down to searching junkyards and not having luck there either. Does anybody here have any idea where to purchase a new/rebuilt one?
Old May 1, 2020 | 06:19 PM
kenny nunez's Avatar
kenny nunez
King pin bushings
If you have the bushings most automotive engine machine shops can press and Sunnen Hone to fit the kingpin.
Where are you located ? There was a time when NAPA could do that .
Old May 1, 2020 | 06:48 PM
Castaway71's Avatar
Castaway71
Houston, tx area. Gonna call them now.. thanks for the lead....
Old May 1, 2020 | 07:17 PM
Franklin2's Avatar
Franklin2
Most machine shops are going out of business as you are finding out. I would check with the big truck shops. Most all the big trucks still run kingpins. Only problem maybe the people they use might not have a reamer small enough for your truck.
Has anyone tried the no-ream king pin kits? Do they make them that fit the smaller trucks?
Old May 1, 2020 | 09:20 PM
FuzzFace2's Avatar
FuzzFace2
First thing you need to know if you don't already is our trucks have 2 different size kingpins.
5 x 5 wheel bolt pattern and non-power brakes uses the larger pins.
4.5 x 5 wheel bolt pattern and power brakes uses the smaller pins.
I checked with a speed shop the does engine machine work and would not touch doing the pin.
They and others put me on to a regular machine shop and they said they could do them.
Well yes they got the old ones out and new in just nut far enough I found out and they did ream the bushing so the pin fits each one but did not ream them all the way across both bushings so could not install the pin.
I had to hone the bushings and drive the pins in and they were to tight.
Good luck
Dave ----
Old May 2, 2020 | 07:20 AM
Castaway71's Avatar
Castaway71
Good luck
Dave ----
Yes I did find out there are 2 sizes and had no idea which ones to buy because I couldn't mike the one I had. Your post clears that portion up. All 5 places I drove to told me hell no we don't do that. Guess I'll salvage yards next. Ebay has some but thats sketchy as you don;t know the condition or size pin will fit the beam I have.This one doohickey is holding up my rebuild and has slowly become a PITA..
Old May 2, 2020 | 08:12 AM
Franklin2's Avatar
Franklin2
I thought you had a f250 or 350 2wd with the kingpins and a straight axle. If you have a f100 with the twin I beam and kingpins, it wouldn't take me 5 seconds if it was my truck to go down to the junkyard or look on facebook market place or craigslist and get a f150 with balljoints and bolt those axles in place, and bolt the rearend in place also if you are going to change wheel lug patterns.
Old May 2, 2020 | 08:19 AM
kenny nunez
King pins
You can buy the correct reamer from a machine tool outlet like MSC or Grainger. I even reamed mine with a wheel cylinder hone inside a parts washer. To really do it correctly you need an adjustable reamer with the centering cone which you could also buy and have your own. I bet in Houston someone there has one in stock.
Old May 2, 2020 | 08:23 AM
Franklin2's Avatar
Franklin2
I was just looking, speedwaymotors sells a reamer for sprint cars. It's for a .859 kingpin. The reamer is .860. I don't know what size kingpins he has.
Old May 2, 2020 | 08:36 AM
FuzzFace2's Avatar
FuzzFace2
That works if the junk years by you have older trucks. Most will find if they live in larger cities they don't keep the older stuff because of room.
When I lived in CT the yards only kept 10 years or newer stuff everything else went to the crusher.
But I did look into buying a parts truck to switch to ball joints and DJM drop beams at one time.
When the machine shop messed up the reaming where the pin would not pass thru both bushings at the same time I also used a wheel cyl. hone but did it on the bench with WD-40 for lube.
But you are 100% right on needing the centering reamer. I did buy one to ream mine again as the steering wheel will not return to center and think it is because they are still to tight.
Old May 2, 2020 | 09:11 AM
FuzzFace2's Avatar
FuzzFace2
Castaway, I think it was on here that someone did his own bushings at home, pressed them out & in do a search.
I don't know what he did for reaming or maybe that is who told me where to get mine?
I got mine off Ebay and it came from the Ukraine. Was $100 and took for ever to get here to the point I though I was out the $100.
I found the post where the member did his own bushings https://www.ford-trucks.com/forums/1...n-removal.html
Dave ----
Old May 2, 2020 | 12:16 PM
Franklin2's Avatar
Franklin2
Looking at his profile, he does have a f250. I was looking for someone, I don't know if it was him or someone else, but there are some yards in Texas with these trucks sitting around. They have a lot of room in Texas
Old May 2, 2020 | 12:55 PM
yardbird's Avatar
yardbird
I would use a set with nylon bushings. They will last pretty much as long as metal if kept greased. No reaming. I've used them on trucks all the way up to C50 Chevys with good results.
Old May 2, 2020 | 04:12 PM
Franklin2's Avatar
Franklin2
Do you have a link or know who sells them? Brand name or something?
Qwik-fit by Stemco makes no ream kits, but they are still metal. I don't know how they work.
There is also a True-fit line. I am not sure what size he needs, some of these look like big truck kits.
Old May 2, 2020 | 04:20 PM
yardbird's Avatar
yardbird
What vehicle is he working on? All I got was F250. Don't know year or anything more than that.
