I remember reading in a car mag once that you really want to have hard brake line for most of your runs as hose will really give your pedal a soft, spongy feel.
No problem. I try to keep all the information in a spreadsheet so I can figure what I used in 10 years when I have a problem with something.
Right now I am running the stock 79 f250 brakes front and rear. So drums in the back.
The booster is a ACDelco 178-1040 that was new. I think I ordered of Amazon for 150.
the fitting for the booster are:
Earls 961955ERL -6 AN Male to 16mm x 1.50 Male
Earls 961956ERL -6 AN Male to 18mm x 1.50 Male
I want to say I found a kit on ebay that had the two main lines along with an an adapter for the return for less later.
Is that for the hydraulic lines? My petal is very touchy compared to any of the newer cars I have driven lately. My brakes might also be more sensitive because of high ratio pedal it had for the original non-power brakes.
