Brake problems 68 F600 Dump
Need some help on 68 F-600 Brakes:
1) Everything Shoes, Whl Cylinders, hardware front and back is new. Master Cylinder is new.
2) Problem is Back Brakes lock up in rear after some driving and heat build up. Never feels like the front brakes engage at all. I have adjusted the shoes front and back. Pedal Travel might be 1/2 inch at best.
3) I have attached pics of the Vin Plate, Booster and Master Cylinder that is on the truck. I'm no engineer but I feel I don't have enough pedal travel to push fluid to front brakes or pull the fluid back from the rear wheel cylinders once the pedal is released..
4) Not sure the Booster on the truck, came on the truck, or I'm missing a spacer between the Booster and firewall. Some one used lug nuts over the studs to pick up Booster spacing so the rod would connect to the pedal. Rod is too long without spacing.
From looking at the Vin Plate Booster and Master Cylinder does anyone know if this truck even came with a Booster.
Does anyone know a Part Number for a Dual Port Master Cylinder that will fit this truck and the right proportioning valve to do away with the Booster.
Thanks
Don
Lug nuts for spacers, rod too long, limited pedal travel all point to a mismatch of components at best.
See if there is anything left of an old system.
Some basic photos and explanations:
Dave's Place - Hydro-Vac Info
What might be what your system should look like:
https://www.fordification.com/tech/i...akes03_MPC.gif
Also, to obtain proper brake service parts, one needs to know the brake size (width of shoe - inner dia of drum).
Even if you have the build sheet, it references directly to the MPC. You are going to need either a WSM (shop manual) and/or period MPC (or ND).
Below is a cropped dash mount.
Again, you need to know brake sizes to get into the correct parts list.
EDIT -
So the truck as you got it had a single hyd system with no booster? Someone tried to add a booster without a split system master cylinder?
Thanks for the info no Hydro Vac system. No brackets under the cab and no vent tube. We have a 70 f-600 parts truck that has that system. So if this truck had a booster it was firewall mounted. I think the problem is the booster. The booster on the truck is the same booster as a 70 Model Louisville. So the problem is mixed components. I will keep working it. Do you think a none booster system will work. I'm thinking of going to another firewall mounted master cylinder and see waht happens.
Thanks
Southriver
The diagram posted is a great help. This truck didn't have the under the truck Hydra Vac system. Brackets under cab and no hole in floor pan for vent hose. I do have a parts manual and will go to that. This is a dash mounted system I feel certain. The back brakes are 15x4, not sure on the front will check but I think they are 14x2. I will reference the manual and start the hunt. Do you feel just a two port Master Cylinder the right proportional value and no booster would work?
Thanks
Southriver
The valve you are describing is not a Proportioning Valve but a Pressure Differential Valve.
The donor truck you are describing may well have everything you need to changeover. You might have to buy a reman booster and/or MC but at least you will have exchange cores. I can also give you original FORD PN's so that a changeover catalog will be easier to use.
Just for my curiosity, can you show a reverse photo of your present booster and MC?
https://www.ford-trucks.com/forums/8...00-brakes.html
I would definitely have power assist. You need all the help you can get to stop these, and in normal driving, the power assist makes driving them more pleasant.
Good luck with it!
You ask that I send you some more pics of my Booster and MC. They are attached. Still looking for a donor truck and other parts options to go with the right stuff.
FORD did have SGL HYD on later models. I thought you said you have a 70 SPLIT BRAKE donor? Otherwise I can give you booster I.D. NOS if you decide to stay SINGLE.
I thought maybe you had given up.
No I have not found a split donor yet. I had a 70 Louisville which has the exact same booster as the one in the pic I sent you (much larger brakes system than what I have. If you have a Part # for NOS booster and MC that should be on my TRUCK Please send.
Thanks
Southriver
Thanks
Southriver
It appears to me your truck has/had a dash mouted booster at some point due to the appearance of the mounting position of a booster (paint not faded) -
Your application is shown on the chart below - Line 108. It calls for a MIDLAND BOOSTER (PN shown will be vendor).
1970 APPLICATION is Line 111. It calls for a different booster (on split system).
Line 108 below will give you FORD PN for BOOSTER and MC
It appears C9TZ 2005-E is the FORD PN you need. You will have to have the FORD PN crossed to current MIDLAND and see if a TRUCK PARTS HOUSE can order a reman and then compare.
Ask if I have confused you.
If you decide to go split, you will need a donor as they are completely different (hydraulic systems) (IMO)
