Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Sync 3 install fails with INSTL_ERR01
Old Apr 30, 2020 | 01:44 AM
Dogturd's Avatar
Dogturd
Sync 3 / Sync3 upgrade fails , displays error INSTL_ERR01 - workaround below.
Updating Sync 3 from 2.0 and 2.1 to 3.0 fails with above error message. Install instructions say to use a 32 GB or higher USB flashdrive. In my case, I was using a 64 gb flash drive which would fail the upgrade as above. Next I tried a 128 gb flashdrive, same failure. I repeated a few times. I also validated the drive was working fine.
The resolution for me was to use a 16 gb USB flashdrive, make sure it is formatted with Fat32 only, copy the files and rerun the installation. Since I did not have a 32 gb drive I could not test it, but it certainly failed with 64 and 128 gb drives.
I am unclear of the reason why, but I suspect that there is a bug using USB drives > 32 gb in size, or with the filesystem type, or the combination of the two. Many operating systems have bugs dealing with filesystems or address ranges greater than 32 gb, or possibly the bug is limited to the installer. The 3.0 upgrade is less than 4 gb in size, so it fits comfortably on a 16 gb flashdrive. I can see that the base firmware / OS seems to be some derivative of Linux, possibly Android, but can read a Windows style filesystems, so this combo may have bug.
leonmckee
Sep 16, 2023 12:27 PM
Dogturd
2015 - 2020 F150
May 5, 2020 07:51 AM
Big-Red-Lariat
2015 - 2020 F150
Mar 23, 2018 05:25 PM
kupaa
Mar 18, 2012 01:01 PM
wildstang
Jun 19, 2009 10:34 PM
