48 F3 Parking Brake & Gauge Senders
Old 04-29-2020, 04:22 AM
Steve Harlow's Avatar
Steve Harlow
Steve Harlow is offline
Howdy
I'm about to make my last big part order, but the parking brake is an unknown.
I got a ford 8.8" rear end in there, and would like to use the stock parking brake setup with the rotating lever with adjustable clevises.
I have the original Timken rear end, and the cables are intact but i fear the cables are incompatable. I also need the clevis and cable to run between the ratchet assembly and crossmember lever, and i don't see a source for anything other than F1 drum cables which are not compatable.
I have no idea what i'm doing here, and if anyone who's been there could help me out i'd apprecaite it.
Also, i would like functional gauges but i have a 302 and 12 volt electrics. Is it possible to get 12 volt flathead senders adapted to the 302? Or elsewise, 302 senders that output in the right range? I know i'll have to run a 6 volt reducer, but knowing ford, they might well have kept the same gauge spec for 70 years.
Thanks.
Old 04-29-2020, 08:54 AM
schoo's Avatar
schoo
schoo is offline
steve I used a s10 chevy rearend with the stock ebrake I sent both cables chevy & ford to a push pull company they made up the cables with ford on one end and chevy on the other,the brakes work great
there are cable company where you live
Old 04-29-2020, 09:28 AM
schoo's Avatar
schoo
schoo is offline
Steve I just looked at California push-pull website they have what you need check there automotive catalog on line
Old 04-29-2020, 09:41 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
As I understand it, your truck has been converted to 12 volts but your instruments are still 6 volts through a voltage reducer?
Old 04-29-2020, 04:42 PM
Steve Harlow
It will be, just starting re-assembly now.
I can do without the gauges if need be, but i would like to know if the motor's about to blow up if at all possible.
I'll give that a look, thanks.
Old 04-29-2020, 05:11 PM
Mixer man's Avatar
Mixer man
You can use the original flattie gauges and single wire sending units with any 12 volt engine as long as a voltage reducer is used for the instruments (temp, oil press., fuel level).
jakevidrine
01-20-2018 10:17 AM
Kazoo
12-02-2012 11:21 AM
lm987
03-22-2008 02:29 PM
48fordf3
02-11-2007 05:16 PM
Woodsman_30350
07-20-2004 04:45 PM
Quick Reply: 48 F3 Parking Brake & Gauge Senders
