2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Need help
Old Apr 27, 2020 | 05:04 PM
Spchisaw's Avatar
Spchisaw
Exclamation Need help
I have a 2007 Ford Expedition. It will crank but will not run. I have replaced the Fuel pump,fuel filter,crankshaft position sensor,cam shaft sensors,new plugs,new coil packs, new throttle assembly,new battery and new battery cables. What else could make it not run? Thank you
Old Apr 28, 2020 | 09:35 AM
pdqford's Avatar
pdqford
Typically, lack of spark or fuel.
Do you have both while cranking?
Old Apr 28, 2020 | 09:39 AM
Spchisaw's Avatar
Spchisaw
Yes I have both of those
Old May 2, 2020 | 12:23 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What is the fuel pressure while you are cranking it over?
Old May 2, 2020 | 02:02 PM
gwcloud's Avatar
gwcloud
When you say you have spark and fuel how did you test for each?
Old May 8, 2020 | 02:02 PM
Spaznaut's Avatar
Spaznaut
A little squirt of starting fluid in the throttle body will tell you if its spark or fuel. You need a gauge on the fuel rail to see if it actually has fuel. Check fuses to make sure injectors are getting power. You'll have to get a spark tester and take off a coil pack and spark plug lead to see if actually any spark. Then you may have to work your way back to the computer.
Old May 19, 2020 | 05:59 PM
OldChief's Avatar
OldChief
Had same issues with a 99 4Runner. Replaced fuel pump & filter, crankshaft sensor, airflow sensor, O2 senssor, plugs, coil packs, and even the hanging xmas tree on the front mirror. It seemed to get better with each fix but still would die out, which was frustrating. Poured a little fuel down the throttle and it woke up for a few seconds. After a while, got it to run (although really rough idle) for a couple of minutes. To make a long story short, it was water in the gas. Initially checked for that by doing the gas in a glass test, but didn't see any separation. New gas and some STP and it was quickly back on the road. TV reported others with same issue a couple of days later in this area from the same gas station chain.
Hope this helps and hope ya get it fixed. Did you fix it yet?
murphym84
16
Dec 26, 2011 05:05 PM
BlackLabel78
Feb 27, 2010 08:01 AM
nesty
Aug 29, 2007 08:19 AM
PAPPYBALL
Jun 5, 2007 08:31 AM
Mestrell
Electrical Systems/Wiring
Mar 15, 2005 12:23 AM
