Morimoto LEDs
Old Apr 30, 2020 | 08:25 AM
  #31
Rooftop's Avatar
Rooftop
Old Apr 30, 2020 | 09:18 AM
  #32
titus_4's Avatar
titus_4
Originally Posted by Rooftop
there’s a video on the f150 so I asked them about a superduty version and they said it’s coming
Good to know. Thanks for the video!
Old Apr 30, 2020 | 05:51 PM
  #33
Nick-ApolloOptics's Avatar
Nick-ApolloOptics
Former Vendor
Originally Posted by titus_4
So for someone with a 19 that was close to buying them, should a guy wait to see if they revise the 17-19 lights?
There won't be a revision to the 17-19 headlights.
Hybrid? As in led and halogen? Is that really a step forward?? Was there a video that headlight revolution talks about it?
However, a hybrid version is coming. The hybrid version will come at a cheaper price point. It will use LED high and low single projectors and will use incandescent turn signals. It will be a downgrade in output and features from the current Morimoto XB Super Duty headlights for the 17-19.
Old May 5, 2020 | 06:36 AM
  #34
titus_4's Avatar
titus_4
Slightly off topic, but does anyone know if I were to plug factory LED lights into my stock halogen connectors, would I get any light output from the LEDs? Just wanting to verify that the factory LED set is functional. Will it mess anything up on them?
Old May 5, 2020 | 06:43 AM
  #35
AdirondEx's Avatar
AdirondEx
Temporarily Deactivated
When I was looking into converting to OEM LED's I thought I discovered I needed a new/special harness and ballast for them to function. Not sure about messing them up.
Old May 5, 2020 | 06:51 AM
  #36
titus_4's Avatar
titus_4
Right. The Retrofit Source has a harness or you can make the changes manually in forscan. I was just wanting to know if they would power up at all with factory connections to test that they work properly before going any farther.
Rich in CO
Sep 26, 2010 05:36 PM
