93 Lightning Differential fluid capacity
Old Apr 26, 2020 | 02:26 PM
Lariat 86's Avatar
Lariat 86
Does anyone know how much rear end fluid goes into a 93 Lightning 8.8 with 4:10 posi.
Old Apr 27, 2020 | 02:26 AM
Fifty150's Avatar
Fifty150
Are you taking off the differential cover and cleaning out the gear box? When you replace the differential cover, you will fill through the check port. You can also insert a tube into the check port, and vacuum out the old fluid, then refill. You will add fluid until you can't add any more. As fluid dribbles back out, that is the correct fill level. Any other measurement is irrelevant. But to answer your question, the capacity is 1.9 liter. So buy 2 quarts. 1.9 liters = 2.00771 quarts. If you really want to, buy that extra quart, and top it off until you fluid spills back out of the hole. The game changes when you buy aftermarket differential covers. A Mag Hytec has a 4 quart capacity. But you can still fill until fluid spills out the check port. Same idea.
Old Apr 27, 2020 | 12:32 PM
Lariat 86's Avatar
Lariat 86
I have the rear end out from under the truck right now and removed the pan and old fluid and put the new fluid in and reinstall the cover before putting it under the truck. The cover is the factory original. I put two quarts in minus 4 ounces because that’s how much friction modifier I put in it. Wanted to make sure I hadn’t over filled or badly under filled it. Thanks for the info.
Old Apr 27, 2020 | 02:15 PM
Fifty150's Avatar
Fifty150
After you reinstall, double check the full level.
Old Apr 27, 2020 | 06:01 PM
Lariat 86's Avatar
Lariat 86
Thanks again.
Lariat 86
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Oct 10, 2020 07:46 PM
KLINE925
Oct 8, 2006 10:51 PM
