batteries keep dying
Old Apr 23, 2020 | 10:38 AM
Dakota Bowman's Avatar
Dakota Bowman
Question batteries keep dying
i have 2006 ford f250 diesel 6.0 and my batteries keep dying i changed the alternator but same thing.
Old Apr 23, 2020 | 12:21 PM
AK4x4's Avatar
AK4x4
Check the voltage, both DC & AC, with the truck running. DC voltage should be around 13.8 up to 14.7. AC voltage should less than 0.5 volts. If both voltages check out then a parasitic drain is likely your trouble. However, if either the DC is low or the AC is high you have a charging system problem. Look for past posts by user, TooManyToys, he has produced a wealth of great charging system info. Good luck, Russ
Old Apr 23, 2020 | 03:08 PM
Dakota Bowman
Question
yeah its 12.31 when car is on so guess that a charging system problem?
Old Apr 23, 2020 | 03:43 PM
TooManyToys.'s Avatar
TooManyToys.
That depends when you are testing that voltage. If the glow plugs are still energized you'll see low numbers. You have to wait for a full two minutes out.
Along with all the good info Russ mentioned, the batteries need to be capacity tested for how many CCA they are capable of.
Old Apr 23, 2020 | 04:01 PM
bismic's Avatar
bismic
I must be a paranoid nut. I am frequently charging and load testing my batteries (individually). That is in addition to watching the cranking and idling voltage on every start up. I hate to be surprised with a failure in the starting/charging system. I also hate to see that vicious cycle of bad alternator results in ruined batteries ...... extreme demand from bad batteries ruins alternator ...... etc.
I suppose some people have good service without such attention, but I never have - not in any diesel since first buying the 6.9L in 1988.
Old Apr 23, 2020 | 04:39 PM
TooManyToys.
I'd rate you as an enthusiast Mark, not paranoid. I'll capacity test every 6 months or more, do weekend charges occasionally (monthly?), a deep restorative charge at least once a year on the truck.
Old Apr 23, 2020 | 07:55 PM
F550 6.0's Avatar
F550 6.0
What do you do for the "deep resorative" one year charge? Extended trickle charge?
Old Apr 23, 2020 | 08:13 PM
TooManyToys.
No, I use my CTEK MXS 5.0 which has a "restorative" charging cycle. One of my other chargers has a "desulfation" charge cycle. Either help in extending the life cycles.
Between home and farm, not counting a motorcycle, I have 18 batteries to keep maintained so it's not an occasional chore, and expensive if I needed to replace them all in short order.
Old Apr 24, 2020 | 06:54 AM
F550 6.0's Avatar
F550 6.0
Looks like a great product, esp the compensation for different temps. I use a desulfation trickle charger for boat and chipper batteries, can take forever to charge a low one but better for them.
Old Apr 26, 2020 | 11:34 PM
Ford.Dude's Avatar
Ford.Dude
What about driving distance? Commute? Do you drive the truck enough per trip to fully charge the batteries?
JohnNBHS85
Apr 11, 2020 08:54 PM
KitsKid
Sep 16, 2019 04:08 AM
KitsKid
Sep 12, 2019 05:05 PM
1998f150stx
Feb 14, 2016 05:16 PM
shdwlkr
Oct 13, 2008 05:42 PM
