Need wiring info for 2019 F-350 side mirrors
I have a 2019 F-350 Lariat with the power fold, heated, tow mirrors. I want to tie in some led running board lights. The running board lights have the courtesy on-fade off feature, along with constant on, and sequential turn signals. I need to find the parking lights wire, the ground wire, the turn signal wire, and the door assist light wire. There must be 20 different wires feeding into the mirror and I can’t find a current Ford wiring diagram to save my life. I will attempt to get a multimeter and check wire by wire if I need to, but I’m hoping someone has already attempted this and can name the four magic wires for me. Thanks!
So I ended up running wires to the back of the truck and tying into the wires for the 7 pin tow connector. That worked, but now the truck thinks a trailer is attached. If I find a different constant 12v wire to connect to for power, will that fix it, or will any connection to any of the wires associated with the towing harness trigger the trailer connected message?
ideally, I want to install some switches (inside console?) so I can override when these are active. I tow a large 5th wheel so I think the turn signal feature would be good while towing but don't necessarily want it on all the time.
Thanks
SoCalAngler
1999 to 2016 Super Duty
04-27-2019 10:35 AM
Jaime74656
08-25-2016 10:21 PM
