Random Shaking
Old Apr 21, 2020 | 04:34 PM
Janetmylove's Avatar
Janetmylove
Random Shaking
My 1979 F100 is shaking violently when braking. It is random. Might brake 9 or 10 times with no problem, then it happens and it is violent. Brakes have been inspected with no known issues. Help!!
Old Apr 21, 2020 | 04:58 PM
72rtchallenger's Avatar
72rtchallenger
check idler arm ,,pitman arm ,,tie rods and drag link all front end parts
Old Apr 21, 2020 | 05:18 PM
Janetmylove
Would this explain it happening randomly? I drove about 5 miles today, braked probably 15 times and it did I twice????
Old Apr 21, 2020 | 05:25 PM
72rtchallenger
Yes it could , I have seen idler arms shake randomly when worn out and braking could cause it ,,if rotors are not warped , then there has to be a problem in front end somewhere else ,,of course the king pins might cause some issue but unsure if it would cause the shaking ,,look at the front strut bushings as well
Old Apr 21, 2020 | 06:28 PM
FuzzFace2's Avatar
FuzzFace2
I would start with the steering like was said but how old are the shocks?
When braking a load is shifted to the front and the wheels could be bouncing.
I have seen this more with straight axles with leaf springs and hitting a bump at speed.
The wheel starts bouncing as the shock can not keep it under control till you slow down to almost a stop so the wheel stops bouncing.
Dave ----
Old Apr 21, 2020 | 06:38 PM
symonds86's Avatar
symonds86
Dave ----
I agree sounds sounds like i beam version the death wobble
Old Apr 21, 2020 | 06:45 PM
72rtchallenger
Originally Posted by symonds86
I agree sounds sounds like the death wobble
True , there are I-beam bushings an struts bushings , start there as these trucks are old and those bushings dont get replaced very often
Old Apr 21, 2020 | 07:55 PM
John89's Avatar
John89
Check to see if the caliper pins/slides are sticking. Lube them while your in there anyway. Also check the rotors. If disc brakes of course.
Old Apr 22, 2020 | 06:04 PM
Janetmylove
Random Shaking II
Ok, so now it is happening moe oftenand I am beginning to hear a heavy clanking even when not braking. Brakes have been inspected by local shop. Front end parts have been inspected. Several people who drove truck including me feel like it is coming from the back of the truck. Help!
Old Apr 22, 2020 | 06:08 PM
72rtchallenger
Jack up the rear wheels of ground,,use jack stands and spin the wheels and check for noise,,inspect the drive shaft universal joints
78whiteorbs
Apr 15, 2018 08:33 PM
F100Lock
Oct 2, 2012 10:13 PM
akerr71
Oct 20, 2011 06:43 PM
COBRAjrb
Jul 22, 2004 10:48 PM
mike
Nov 19, 1999 01:56 PM
