OBS Dome light mod
Old Apr 19, 2020 | 04:12 PM
DansAstro's Avatar
DansAstro
OBS Dome light mod
I have some LED bulbs leftover from another project I had and decided to throw them in the truck (96 f250 Extended cab XLT). I swapped out the lights in the door then started working on the dome light. I like bright lights, its really handy in every situation, daily driver camping etc. So I took apart the dome line and added some wiring that will let all three interior lights come on when the door is openned. Quick and easy mod that I thought I'd share.
A couple notes if you decide to do this... Use LEDs since they have much less draw. There's a possibility of melting the wiring or cause a fire (unlikely... But I wouldn't risk it) if you use regular bulbs.
Once you do this, all three lights will come on when you switch either switch on the dome light. You'll need to rieplace the upexisting switches with SPDT switches to avoid that, I'm working on and I'll share details once i figure it out. It'll also change the wiring when I do that.
Also make sure you pull all the bulbs before you solder.
(My center light is not LED, yet)
The LEDs were a bit small so I soldered some caps from the old bulbs onto the LEDs to make them work.
Old Apr 20, 2020 | 07:38 PM
TexasGuy001's Avatar
TexasGuy001
That's not a bad idea especially if using LED's shouldn't overheat the wiring then.
Old Apr 5, 2021 | 02:52 PM
CliffytheRed73's Avatar
CliffytheRed73
With some diodes installed pointing towards the "map lights" you can avoid them turning on each other or the center dome
Old Apr 6, 2021 | 09:04 AM
broncobasher's Avatar
broncobasher
On my 90, I couldn't find an LED bulb that fit so I bought a small plug with pigtail that fit a LED bulb, wired it to the existing wiring and fit it in the existing fixture. Works great. No more heating issues as you said.
HoustonDave
Nov 27, 2019 11:13 AM
03X
Jan 15, 2016 10:54 AM
TRENT310
6.7L Power Stroke Diesel
57
Aug 1, 2014 06:33 PM
BroncoRN
Oct 5, 2012 04:45 PM
Shake-N-Bake
Oct 25, 2011 07:42 PM
